Change transmission fluid or not? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-19-2009, 04:59 AM Thread Starter
Txgunrunner's Avatar
I purchased a 99 F250 a few weeks ago that now has 180,000 miles. I'm the third owner. The person I purchased from informed me that the transmission fluid has never been changed because he was told that as soon as he changed it, it would cause the transmission to go out. A few of my friends have advised me also not to change for the same reason, is this just a myth or what? They say if the fluid had been changed regularly, yes. Should I have it changed or not? I checked it and looks like it should and smells OK. Thanks!!!
Txgunrunner is offline
post #2 of 12 Old 07-19-2009, 05:11 AM
I am that hot
superxcrewfx4's Avatar
Dropping the pan and draining the fluid without flushing it wont do any real damage or harm, new fluid is always good, flushing sometimes can do more harm than good. Blow out the cooler lines, drain the tc and drain the pan and refill, you shouldnt dislodge anything in the tranny that is holding it together.
1999.5 Ford F-250 Powerstroke
7.3 Powerstroke Diesel
4" Turbo Back MBRP with 6" Tip Straight Piped!
DIY Intake
Isspro Gauges
Diesel Site Coolant Filter
TW 6 Position Chip
2.5 Inch Leveling Kit
305/75/16 Mickey Thompson MTZ's
239k and COUNTING!!!
superxcrewfx4 is offline
post #3 of 12 Old 07-19-2009, 05:14 AM
Type 2 Sniffer's Avatar
For sure don't flush it though. Don't ask me how I know!
Si vis pacem, para bellum
2002 F-250 Lariat
7.3L Powerstroke: Zoodad Mod, Foil Delete, NAPA Intake, MBRP 4", ISSPRO 3-gauge
Type 2 Sniffer is offline
post #4 of 12 Old 07-20-2009, 12:07 PM Thread Starter
Thanks guys, do I need to change the filter? Does Blackstone Labs analyze transmission fluid also?
post #5 of 12 Old 07-20-2009, 12:16 PM
CUMMINS_KILLA99's Avatar
if by simply flushing your tranny causes it to fail it was on its last leg to begin with
99.5 F-250 4X4 LARIAT
35IN. BFG KM2s
2.5 IN. LEVELING KIT
AEM AIR INTAKE
TS CHIP (TUNED BY MATT @ GEARHEAD)
GARRETT 38R TURBO
6.0 INTERCOOLER
4IN. TURBO BACK EXHAUST
CSE FAB SINGLE BLACK 8IN. SLASH CUT STACK
CCV MOD
CSE PRE PUMP KIT
TRANNY COOLER WITH FAN
CSE FAB PORTED EXHAUST FLANGE
TIM MOYE TRANSMISSION
CUMMINS_KILLA99 is offline
post #6 of 12 Old 07-20-2009, 01:09 PM
Quoted: 5 Post(s)
flushing tranny is ok, power flushing tranny is bad. flushed many a transmission in my day.....its all about the equipment. some machines force the fluid through, and some allow the trannsmission to suction new fluid in. you dont want to force the fluid through.
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #7 of 12 Old 07-20-2009, 01:11 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Best advice you could get..
CT Performance, Inc. is offline
post #8 of 12 Old 07-21-2009, 05:41 AM
OHBandit's Avatar
I second that.
2003 F350 Lariat Crew Cab 8' Bed 4X4 7.3 PSD
4" Pro Comp Lift
MotoMetal 951's W/Toyo MT 35X12.50's
Power Hungry FU Chip
ITP 4" Ported Compressor Housing
4" Turbo Back Exhaust Straight Pipe
S&B Air Intake W/Zoodad mod
Pillar Gauges: Boost, Trans Temp, Exhaust Temp
6.0 Trans. Cooler
Recon smoked cab light lenses
LineX Bed Liner
OHBandit is offline
post #9 of 12 Old 07-21-2009, 06:00 AM
twistedmx1's Avatar
Ha Ha Ha
When I get my reman in I'll be sure to flush it regularly.
Jared
97 F-350
Reg cab long bed
TW Chip
Intercooled
3" Down pipe
4" SS Magnaflow
DIY Intake
Boost, Pyrometer, Trans temp gauges
Sunroof
twistedmx1 is offline
post #10 of 12 Old 07-21-2009, 06:51 AM
2nd this.
I would change the fluid using the internal pump. My fathers 00 X when purchased was shifting odd/rough etc. 2 fluid changes and 30K miles later he tows a 30TT with no issues.
Txangler is offline
