Location of your egt thermocouple - Ford Powerstroke Diesel Forum
Old 02-11-2007, 06:27 PM
Send a message via AIM to Albie30 Send a message via Yahoo to Albie30
I was wondering where eveyone had their thermocouple for the egt gauge I ve got mine in the drivers side exhaust manifold Right where edge says to pit it but I think that could leadto problems only reading temps from one side of the motor Would it be better to put it in the down pipe???
Old 02-11-2007, 06:30 PM
im fat and ugly
no yur in the right place leave it there
Old 02-11-2007, 06:33 PM
I think you have it in the right spot.there will be some one that has more info on this then me.
International Threat
Unless you're a competition diesel then one place is fine - most all cylinders will be very close in temperature. I've heard of people putting a probe at each cylinder but that's on a pulling truck...
Old 02-11-2007, 06:36 PM
im fat and ugly
EGT probe placement
heres a guide
Old 02-11-2007, 06:43 PM
Thanks How is that pre turbo ???
Old 02-11-2007, 06:47 PM
im fat and ugly
good to me , max i get is about 1350 but thats pushin it
pre is the way to go
Old 02-12-2007, 12:40 AM
I've got mine in the up pipe (dunno what ya call it) that connects to the driver side manifold. Didn't wanna pull the manifold and felt kinda sketchy at drilling the manifold on the truck. So when I did my 5" I pulled the pipe, drilled it, cleaned all shavings out real good, mounted the clamp on style thermocouple, and called it a day! Should be as accurate if not real, real close to having it in the manifold itself, I think .
Old 02-12-2007, 01:04 AM
Mine is in the drivers manifold. Everything I have heard says that a probe in the down pipe doesn't react fast enough, and shows a lower temp than at the manifold, so you have to do some figgerin to match up if you know what I mean
Gord.
Old 02-12-2007, 06:22 AM
Desert Shield/Storm Vet
Yeah in the manifold its reading is coming right off the engine before the exhaust gets to the turbo where as in the downpipe it has had time to cool and I have heard could be 300 degrees cooler. Im sure there is some cooling going on before it hits your turbo from the exhaust manifold reading but at least you know by the time it hits the turbo you won't be maxed out.
