F-550 codes - Ford Powerstroke Diesel Forum
post #1 of 16 Old 07-15-2009, 04:58 PM Thread Starter
Ryan Rønning's Avatar
Quoted: 6 Post(s)
F-550 codes
Just got home from the wind farm pulling the codes on the F-550. I got P0603 KAM error and P0340 CPS. I know what both are but I am curious as to why I got the KAM error. Its to my knowledge that this error tends to come up when the truck has been tuned or reprogrammed and I know this truck has not been so I am at a loss.
Any ideas.
Also, how is the CPS to replace?
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #2 of 16 Old 07-15-2009, 05:12 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
CPS is a 10 minute deal
http://www.powerstroke.org/forum/7-3...procedure.html
What are you using to pull codes?
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 16 Old 07-15-2009, 05:15 PM Thread Starter
Quoted: 6 Post(s)
Snap-on scanner.
post #4 of 16 Old 07-15-2009, 05:17 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Snap-on scanner.
Are you sure its never been tuned. Did you get the P0603 before or after you cleared codes?
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 16 Old 07-15-2009, 05:23 PM Thread Starter
Quoted: 6 Post(s)
Well the owner (original) says it hasn't but it is a company truck so lots of different people drive it.
I got the code before I cleared.
post #6 of 16 Old 07-15-2009, 05:28 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Remind me What are the issues with the truck that prompted you to pull the codes? Was it a no start? If so change the CPS then go from there
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #7 of 16 Old 07-15-2009, 05:42 PM Thread Starter
Quoted: 6 Post(s)
It will generally start fine and run and drive fine but will randomly just shut off. If you need it to start right back up you have to disconnect the batts to reset it but if you wait a while it will usually start. But its like someone just reaches over and turns the key off while you are driving!
post #8 of 16 Old 07-15-2009, 05:43 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
CPS should take care of that
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #9 of 16 Old 07-15-2009, 06:02 PM Thread Starter
Quoted: 6 Post(s)
Hope so. What do you suggest, Napa, Advance, ECT?
post #10 of 16 Old 07-15-2009, 06:06 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Ford dealer. Believe it or not thats gonna be the cheapest. Do me a favor post the VIN. Then crawl under the truck and tell me if the CPS is black or Gray. If its black you get a free one But you have to get the truck to the dealer in most cases to get it
Email:
Edge Insight CTS
Coolant filter
Dave is offline
