Foil Delet
What do I need to remove to take the tube out so I can delete the foil on my '02 f250? Just double checking before I do it tonight.
there is a write up on here on how it is done... taking the inner cooler tube off isnt the problem, trying to get that insulation and glue off is a pain in the butt
Wire wheel for a grinder works good. Good old fashioned elbow grease and a scraper works too. Once I got the bulk off, I kept soaking the glue with Goo-Gone and scraping till it was all gone.
I've read a few of these foil delete threads now. But what advantage is it to remove the foil? What is the sound difference I keep hearing about? Why is the foil and insulation there to start with. Seems like it should serve some sort of purpose but must not be too important.
It just makes it whistle more in the cab pretty much. Maybe a little louder on the outside. Its worth doing
