Truck over heating.......Y pipe???
I have recently started towing a travel trailer (approx 9000lbs loaded) and my truck overheats when towing up hill.
It is a completely stock 02 7.3 crew cab. I spoke to a diesel mechanic today and he told me that it is more than likely the Y pipe leaking that is causing the overheating and he recommended using the International Y pipes instead of the Ford ones. So, I have a few questions. Is an up pipe and a Y pipe the same thing? Does anyone have the part number for the international parts? How bad is this job to do? The mech. wanted $1100 to do the job. Thoughts?
doin that sucks....there is no room....its easier to pull the engine and do it....
I take it you are talking about the bellowed up pipes? There is a write up for it in the tech files Im pretty sure
it should be kinda easy to tell....just look for soot all over everything....
thats how i found mine...
Does anyone know anything about the International parts conversion?
i will disagree badly with the y-pipes causing the overheat concern , i would guees fan clutch is more plausible to think will cause this
Or water pump?
Leaking up pipes will kill your power. |
Leaking pipe = less boost. Engine has to work harder to make up for the lack of boost (especially up hill)....makes sense to me.
Ummmmm, I would be way more inclined to take Scuffy's advice....... Also, check out what Scuffy does for a living...
