2 Quick Questions - Ford Powerstroke Diesel Forum
Old 07-10-2009, 07:35 PM
2 Quick Questions
On my '99 I need to know what fuses always have power even when the truck is off?
Also what is the cheapest place to get new batteries and what do yall suggest?
Old 07-10-2009, 07:44 PM
Almostdunfukinwidit
Cheapest would be the gold series from Wallyworld. Or autozone duralast. Both good batteries
Old 07-10-2009, 08:11 PM
ummm a few that always have power are the cigarette lighter...and i think that possibly your dome lights are always powered....just depends on how you tap into it.....
good batteries can be bought at advance auto for pretty cheap.....
Old 07-10-2009, 08:39 PM
Location: West Jordan UT, Currently working in Colo. Springs CO.
I went with Duralast Golds from autozone, 1000 CA and 800 CCA if I remember correctly, I don't feel like going outside right now so I'm not exactly sure. Plus they had a really good warrenty.
Old 07-10-2009, 08:46 PM
those would be life time warrenties....they should be....idk i like advance auto batteries better....could be b/c i used to work for them though.....idk around here no one likes auto zone....
Old 07-11-2009, 04:50 PM
Thanks guys. Something is killing my rig and my Optimas have to be toast by now + they are out of warranty!
Old 07-11-2009, 05:02 PM
unlpug your ignition and see if that stops it.....buddies truck did that...his key switch went out and left power on haha some how he didnt notice his fan runnin
and check your glowplug relay....had that on a buddies 02 stroker....killed his batteries real fast....it kept cyclin even when off.....
and last check your starter.....make sure no wires are touchin or groundin...
Old 07-11-2009, 05:07 PM
I have duralast golds, excellent battery!
Old 07-13-2009, 03:25 PM
Took the truck to the dealership today and had them test out the electrical system. Turned out that one of the plates in my passenger side battery warped into another one and the battery short circuited itself. I didnt even know that could happen but apparently its caused by repeated charging and killing of the battery. So one new battery and all is well again
Old 07-14-2009, 09:27 PM
ive always had good luck with batts from costco cant remeber the warranty but if you do take them in its no questions asked i like that it seems like everyone trys to play a bad batt on you some how then try to not replace it
