what is typical oil usage? - Ford Powerstroke Diesel Forum
Old 07-10-2009, 06:51 PM
I seem to have to add a quart every 1000 or so, is this normal?
Old 07-10-2009, 06:55 PM
I never have to add that much oil every 1000 miles and my truck even has a small leak. so i would go with no not normal
Old 07-11-2009, 07:36 AM
Does it look like it's burning oil (from the exhaust), or does it look like it's hemorrhaging oil from some where on the engine? How many miles does it have?
Unless it is an obvious leak, I wouldn't worry about it. If your truck has 200K+ miles there is no point in doing major repair to find a leak, then have the truck die 50,000 miles down the road due to bad cam bearings or something. Just keep putting oil in it. Now, if there is a performance problem associated with the oil leak, then you might think about finding the problem.
In the mean time, the extra oil between oil changes will keep the cleaner over all.
Old 07-11-2009, 07:12 PM
I've never seen any drips under the engine, and the exhaust seems OK, although my panel behind the exhaust gets pretty blacked up. I'veot 160k on the truck now.
Old 07-11-2009, 08:52 PM
I would agree!
Old 07-12-2009, 06:53 AM
That's kind of a low mileage to be using oil like that. I still wouldn't worry about it though. It would cost waaay more than the cost of a few quarts of oil to get it re-built. Just keep adding it, and don't worry about it.
Old 07-12-2009, 06:56 AM
ADMIN AND TECH
if i had to guess on this problem, i would guess your are losing oil thru the internals of at least one injector , seen this quite afew times, no external leaks on a vehicle without that many miles , what needs to happen here is the injectors need to be pulled and if you have a local ford dealer near you , have them pressure test the injectors , there is a tool made every ford delaer should have one , the injector mounts in it , and shop air is applied , if oil runs out the spill spout during this test the injector is bad , i dont know what kind of mechanical abilities you have but if you are willing to pull them out , ship them to me , i'll do this for you , i think you will find your problem there , pm me if you are interested
Old 07-12-2009, 07:37 PM
i dont agree to some of that, i had the same issue in my old truck, no blue yadda yadda and cylinder 8 was actually losing compression and my truck only had 100k miles, the reason for not seeing the blue at all is the fact our engines run so hot, when you put a lil oil in it at a time it burns it off you wont see it until it gets worse or on itial start up the blue wont go away right away, so no not good, dont just keep putting oil in it, take it in and get a compression test done, check for blow by, catch it early easy rebuild, catch it way down the road youll need a short block..
Old 07-13-2009, 04:22 AM
ADMIN AND TECH
so just because yours had a compression issue means his does too , oh now i see sorry for my ignorant post , to the original poster , i think you will find in the end that i am correct with what i posted
Old 07-13-2009, 04:38 AM
Send a message via AIM to ABoyAndHisToys
..... Why ya being so ignorant Scuffy?....... I agree 100% with Scuffy. Exact same issues the OP is having I had and the fix was pressure testing the injectors..... as always Scuffy......
