DIY intake help - Ford Powerstroke Diesel Forum
Old 07-04-2009, 09:25 AM
DIY intake help
got my 6637 filter and put it all on,but when the truck is not moving and I rev the engine it dies, but if I drive down the rode it does fine, any ideas y?????
Old 07-04-2009, 09:42 AM
No idea. That sounds weird to me! Deff not what it should be doing!
Old 07-04-2009, 09:43 AM
Does the SES light come on when it happens? Check all the sensor plugs around the air intake, its common for one to knock a plug loose/off installing the 6637. Also check your drivers side injector harness plug. It rides right up underneath the intake pipe, and you may have knocked it loose. Pay attention to where you put the air temp sensor.(The lil probe lookin thingee at the back of the airbox) Make sure its not laying against metal.
