Old 07-03-2009, 04:28 PM
RadarRider RadarRider is offline
Central Scrutinizer
Oil Capacity: OBS vs. NBS
I just finished up working on my instructor's '97 F-350. It needed a new oil pan & dipstick tube. When I got the oil pan, I measured all dimensions to make 100% sure it was the same size as the one that came out & it checked out OK. I also made sure the new dipstick tube was the same length & besides a really bad bend in the old one, they're both the same length. Now, when I put the oil in it today, I primed the oil filter & installed it. Then I put in 3gal of oil & the dipstick's reading almost to the full line in the operating range grid...... I haven't gotten to start the truck yet to build up oil press & let it warm up(because of rain), but whatever little the filter would need to fully prime & whatever amount of oil will fill the engine I know won't require another gallon. My NBS takes about 4gal. Do OBSs have less oil capacity than an NBS????
Old 07-03-2009, 04:31 PM
ianstew ianstew is offline
Go ahead, swat the screen
i thought they were the same.....
Old 07-03-2009, 04:54 PM
psdmichael psdmichael is offline
They take the same amount of oil.
Old 07-03-2009, 04:57 PM
Dave Dave is offline
Vikings cheerleaders YUM!
Yup both 15 quarts. IIRC there was an updated dipstick for the OBS. I could be wrong though
Old 07-03-2009, 05:05 PM
bockhold bockhold is offline
ssɐlɔ uıɥɔɐǝʇ pǝlıɐɟ ɔıɹǝ
Send a message via AIM to bockhold Send a message via MSN to bockhold Send a message via Yahoo to bockhold
i can get 16qts in when topped off
Old 07-03-2009, 05:07 PM
NOOOOOOOOOOOOOOOO while 1 quart overfull shouldnt hurt anything to seriously 15 is it. Next oil change only put 15 in
Old 07-03-2009, 05:09 PM
well i can dump 15qt in the pan. the filter takes almost 2qts. and after running to prime it, i can put up to 1qt in it after and that will be full or a hair over
Old 07-03-2009, 05:11 PM
Jarrod I hope you are joking here. 15 total between pan and filter is full
Old 07-03-2009, 05:12 PM
Central Scrutinizer
CRAP! I've gotta get this truck started & see what the dipstick looks like after it's been warmed up. I think I did hear the same thing about an updated dipstick though, Dave. Even though the dipsticks were the same length, the bends were different. I'll have to call Ford & see what the skinny is. Thanks, guys!
Old 07-03-2009, 05:24 PM
well the last time i check and did the oil change, that is what it took. the next time i change it ill double check.
15qts is correct. tho
