  #21 (permalink)
Old 07-02-2009, 06:02 PM
CUMMINS_KILLA99 CUMMINS_KILLA99 is offline
my truck just rolled 180000 miles so far all i have replaced is water pump, alternator and the ball joints just had the tranny rebuilt at 174000 miles everything else is original my dad bought the truck new before i got it at 100000 its all in the maitenence. im curious did you by the truck used do you keep up on the maitenence
  #22 (permalink)
Old 07-02-2009, 06:07 PM
monoloco monoloco is offline
When I bought the truck it had about 50k. I have maintained the truck meticulously but I have no way of knowing what the former owner did.
  #23 (permalink)
Old 07-02-2009, 06:13 PM
I should probably say that I have put about 20k on the truck in Baja where the roads are notoriously bad. That could probably explain why I have had more issues than others have.
  #24 (permalink)
Old 07-02-2009, 07:53 PM
Hades212 Hades212 is offline
Mines at 119k and the transmission just shuffled off its mortal coil, as well as the TC, it did it the day after I got done with the entire front end, ball joints, bushings, rotors, and the like, its had a water pump at 80k and a new right front wheel hub at 85k.
I spent several hundred miles going through hay fields and off road pulling tractors, and hay trailers so its no wonder my suspension was shot, and it needed new shocks, I abuse my transmission with higher performance tunes and equipment, personally I think its just the attrition of the truck and what we put em through.
  #25 (permalink)
Old 07-02-2009, 08:06 PM
Ditty Ditty is offline
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
I'm knocking on 250K, bought it with 163K on the dial. I drive the poo out of this truck. I've put THREE ZF6's in it, three clutches, waterpump, some seals, brakes, two sets of tires, and a few other items.
Anyone that's been here a while knows all my tranny issues, mostly mistakes while doing something else or going to a BAD repair shop. Clutches were either me getting the wrong part in the first place or a man. defect. Water pump just replaced for the first time a month or so ago. (Thanks Marty!) Turbo seals, rebuilt turbo etc.
Really and truly, I can't complain a bit!!! 90% of the money invested in repairing the truck is either performance enhancing or due to mine or someone else's mistake. With a 1/4 of a million miles, I'm gonna keep good 'ol Brisco for a while and see just how many miles I can get until he drops a rod or something catastrophic breaks.
  #26 (permalink)
Old 07-02-2009, 08:11 PM
scagmanf350 scagmanf350 is offline
Ive only had like 4 of those repairs (most of them just wear and tear) otherwise everything has been great. Do you beat on your truck, honestly? Cause just looking at that list I would think so but if you don't then I say just bad luck.
  #27 (permalink)
Old 07-02-2009, 08:50 PM
Except for bad roads in Mexico I take really good care of my truck. I run a fs2500 bypass filter and change the oil every 5000 mi. I don't hot rod but I do take it off road some. When I do repairs I always try and use the best parts available.
  #28 (permalink)
Old 07-02-2009, 08:52 PM
bad luck then man dunno.
  #29 (permalink)
Old 07-06-2009, 08:49 PM
tomwhysy tomwhysy is offline
i bought early 99 for 8k ith 141000 miles thats 8000$
then tires 1000$
then ball joints did them myself including new
rotors and pads 780
then injector did it myself 380$
edge juice with attitude 550$
then exhaust MBPR parts only 400$
then all fluids change (all synthetic) 325$
then cooling fan to electrical conversion 680$
then new rear end (i mangled everything insid there)
1900$
=14015$
price to pay for bearly used truck thats only ithin one month!!!
but it could move an mouintain!!
  #30 (permalink)
Old 07-06-2009, 08:58 PM
OregonStroker OregonStroker is offline
oh gosh dont get me started. I BOUGHT one with 218k on it. lets just say OUCH!!! Reman engine/turbo 8600. new turbo (waranty thank god) built trans 4000. new brake rotors pads 700, new suspension 1600, tires 1400, wheels, 400, paint 6k, suspension.... blah blah blah add ons, u joints, gears 2000 (good deal), blah blah blah... blahhhhhhhhhhhhhhhhhhhhhh.... ... i have learned to just forget it. if you want to drive a cool ford, its going to be spendy. it never ends...
