  #21 (permalink)
Old 06-30-2009, 02:56 PM
blacksmokingpowerstroke blacksmokingpowerstroke is offline
so did the fusebox solve your electrical problems?
  #22 (permalink)
Old 06-30-2009, 04:27 PM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
Originally Posted by wriott View Post
your not done yet????? what are you doing on here.... your as bad as Rob
Do you think you are gonna be able to make it the the G2G at my place???
With duct tape and zip ties I will make it.
I am going to work on it tonight around 1030pm.
  #23 (permalink)
Old 06-30-2009, 04:28 PM
I will let you know as soon as I get it in. Which will be tonight.
  #24 (permalink)
Old 06-30-2009, 10:51 PM
Alright now I need to find the General Electronic Module. I have been searching and it seems like it will either be located behind the glove box. Or it is located behind the fuse panel.
Well it is not behind the fuse panel. I know because that is out. Nothing is there. So where is this dang thing at.
  #25 (permalink)
Old 07-01-2009, 07:42 AM
wriott wriott is offline
BUILT & BROKE BY ME
i think its behind the radio...
  #26 (permalink)
Old 07-01-2009, 10:21 AM
There is not one. I called Scuffy up, he looked up my truck and informed me that if I replaced the fuse box. Then I already replaced the GEM.
So now I have an electrical nightmare to find.
Fuel pump is still powered by toggle switch, wipers still come on by themself. But everything points to what I replaced already.
  #27 (permalink)
Old 07-01-2009, 10:35 AM
Dirk Dirk is offline
Diesel Innovations
Body harness issue or there is corrosion on the pins.
  #28 (permalink)
Old 07-01-2009, 10:40 AM
At what connector. I know the ones at the fuse box is good to go.
Quite a few connectors.
  #29 (permalink)
Old 07-01-2009, 10:44 AM
superxcrewfx4 superxcrewfx4 is offline
<-- They eat cell phones
Sorry you are having so many problems. I know on my 150 a few years ago the blower fan was freaking out and they replaced the fuse panel under warranty, so I was kind of hoping that was going to fix your problem. I am going to be replacing my belt, tensioner and upper hose as well, reading yours reminded me that I need to do that soon, 211k and all that stuff minus the belt is origional.
  #30 (permalink)
Old 07-01-2009, 10:46 AM
Diesel Innovations
That's what I can't answer. You'll need to put on your Dick Tracy shoes and start looking.
