Help ? How to install fog light !!!!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-26-2009, 11:33 AM Thread Starter
builtnotbought's Avatar
Exclamation Help ? How to install fog light !!!!!
How and what do i need to install fog lights on my 99 f-250, is there a tech file ? do i need to drill ?
Thanks guys
builtnotbought is offline
post #2 of 5 Old 06-26-2009, 01:46 PM
colinmitchell111's Avatar
i assume your talking about factory fog lights? i just added mine when i did my 05 conversion.. there are holes already there in the bumper, just bolt them in.. as far as wiring, i just ran 2 wires into each bulb and jumped them off the low beam headlight power wire.. there are some guys on here that say you cant do that and you need them on a relay, blah, blah.. and they wont draw enough power, but mine are just as bright as a truck with them from the factory.. hope this helps..
04 F250 SC SB auto 4x4
5" Diamond Eye TB
High idle switch
Zoodad
EGR delete
Sinister coolant filter kit
Upgraded blue FPR spring
CCV Dump
Warn locking hubs
SCT with Looney
colinmitchell111 is offline
post #3 of 5 Old 06-26-2009, 02:07 PM
did you have to remove the bumper? I can't get it thru the opening in the bumper.
thanks
GONEFISHINTODAY is offline
post #4 of 5 Old 06-26-2009, 05:36 PM Thread Starter
THanks man !
post #5 of 5 Old 06-26-2009, 07:52 PM
i put mine on with the bumper off.. it takes about 2 mins to take the bumper off if you have to.. take the 4 18mm bolts off by the tow hooks, then the rubber splash guard underneeth is held on by 4 plastic push clips that you can just pry out with a flat head..
5" Diamond Eye TB
High idle switch
Zoodad
EGR delete
CCV Dump
Warn locking hubs
SCT with Looney
