HELP! Scott! How do I insert my meth in my intake tract.(bung hole)? - Ford Powerstroke Diesel Forum
Closed Thread
Old 06-25-2009, 09:22 PM
Real Men Love Jesus! <><
Just for you big daddy! I wanna learn the easiest way to do it. What size nozzle do you use?
LMMFAO!
Old 06-25-2009, 09:27 PM
ADMIN AND TECH
LMMFAO!
well it depnds on the size of the bunghole in question, if its yours , its huge and out of shape , may want to go with 4 inch pcv pipe to get an acuurate fit so there is no seepage around the edge when installing
Old 06-25-2009, 09:29 PM
what about the arming switch? should I use the standard 2 way, or go wild and have a multi positional 4 way switch?
Old 06-25-2009, 09:31 PM
Chapter Director
Send a message via Yahoo to Dieseltorkin
LMMFAO!
LMAO Before you inject you need to purge the system with a glacier water rinse, that way you get the full effect
what kind of sealer would you suggest for a TIGHT fit? something like peanut butter or maybe just use a good dose of bearing grease?
Wht is wrong with you guys?
Old 06-25-2009, 09:32 PM
ADMIN AND TECH
well thats another situation that depends , (speaking of depends ), anyway , depends on the size of opening , and it also depends on how much liqour you have drank
I was thinking of sparkling water. makes me fell more "special"
do I use a garden hose and a fan nozzle?
Old 06-25-2009, 09:33 PM
ADMIN AND TECH
well , bearing grase works fine in some cases , but there is times when brake clean is need to remove before you go home
Old 06-25-2009, 09:34 PM
ADMIN AND TECH
and i havent even drank anything
Closed Thread
