Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Exterior Discussion
  #11 (permalink)
Old 06-23-2009, 09:34 AM
panteramatt panteramatt is offline
I just put 16x9.5" rims on my 2000 and they had a -17mm offset. Fit perfect.
  #12 (permalink)
Old 06-23-2009, 10:17 AM
caryt caryt is offline
4.5" offset is stock so a those will work with possibly a little rubbing the leaf spring at full lock
  #13 (permalink)
Old 06-23-2009, 11:29 PM
builtnotbought builtnotbought is offline
You mean 4.5 backspace ? i dont get really what backspace and offset is, if i understand good offset is how much they are going to stick out ???
  #14 (permalink)
Old 06-29-2009, 04:02 PM
marcmcg marcmcg is offline
Minou!!!!
La.Minou C rim la c parfait pour toi la moi l mien c des
16x10, 8 on 170 Bolt Pattern
Backspace = 4.5 in.
Max Load = 3420lbs
Finish = Gloss Black
Hub Centric = No
Offset = -25mm
Sa fait que sa va sortir presque comme moi..Jsavais pas tu voulais aller ds des 17 moi..Salut
17x9, 8 on 170mm Bolt Pattern
Backspace = 4.75 in.
Max Load = 3420lbs
Finish = Knight Chrome
Hub Centric = No
Offset = -6mm[/quote]
  #15 (permalink)
Old 06-30-2009, 12:07 PM
WTF>>>
Back space, measurement from the rim to the mounting surface of the rim...so with a 4.5" BS a 10" wide wheel would have 5.5" from the mounting surface of the disk out..if your existing rims are 7" wide then 10" rims would stick 3" further out...BS being equal
  #16 (permalink)
Old 07-19-2009, 09:31 PM
spdjnky_42 spdjnky_42 is offline
Send a message via Yahoo to spdjnky_42
I got 17x9 w/ -12mm and 4.5" they will work. However you have to be careful w/ what size tire you are using. A 17" rim is hard to find anything bigger than 33" for...
