Door adjustment? - Ford Powerstroke Diesel Forum
Old 01-28-2007, 12:37 PM
Thats Mr. Oil Leak.....
Door adjustment?
I thought you could adjust the door catch to adjust the door. My 350 has some wind noise coming in from the passenger side door? Is that not how you adjust it. Can it be adjusted. The catch only needs about 1/8 inch adjustment to close the gap. The noise is getting irritating.
Old 01-28-2007, 02:21 PM
I have the same noise from the drivers side. I tried to adjust the catch on the truck, and it got worse. I finally got it back to where it was, then I adjusted the mechanism on the door. That worked better, but it is still not right. If anyone can tell me how to adjust this, I too would be appreciative.
Old 01-28-2007, 03:54 PM
loosen the bolts on the striker just a little bit, about a 1/4 turn and hit the striker with a block of wood and a hammer. this should tighten up the door
Old 01-28-2007, 06:11 PM
I tried that and it never even moved. Maybe it was just stuck. I didn't want to hit it too hard.
Old 01-28-2007, 06:48 PM
Send a message via AIM to 96EDGEpsd
i dont know about those newer trucks, but on the obs truck you can snake 1/4 inch plastic tubing throught the inside of the weather stripping and it makes it seal a little better...dunno if that wud help ya
Road and wind noise stopped !!!!!!!!!!! - F-Series & Super Duty Diesel Forums
Old 01-28-2007, 07:00 PM
mine does the same on the drivers door, when i have the camper on the air noise is way too loud i asked a body shop if they could adjust the door?of course they said sure!for $70 an hour.so some one who knows the trick? your help would be great.
Old 01-28-2007, 07:57 PM
you have to give it a good hit or two and it will move enough. the block of wood is so you don't miss and hit the door jam. apiece of steel works better.just remember you only need to move it 1/8 of an inch
Old 01-29-2007, 05:55 AM
Thanks Guys. I'll try hitting it again and see.
