Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Exterior Discussion
  #11 (permalink)
Old 05-08-2009, 07:38 AM
Eric Eric is offline
I HAVE POWAH!!!!!
Originally Posted by kolb02 View Post
I just bought everything to do mine, do I need to buy the '05 bumper brackets or will my '01 brackets work? Where is the bumper sticking out? Does it look bad?
You'll have to buy new bumper brackets.....
  #12 (permalink)
Old 05-08-2009, 08:08 AM
bigwhite7.3stroker bigwhite7.3stroker is offline
Florida Stroker
Looks great man
  #13 (permalink)
Old 05-08-2009, 08:20 AM
kolb02 kolb02 is offline
So all the factory 05 fords stick out like that too?
  #14 (permalink)
Old 05-08-2009, 08:23 AM
I HAVE POWAH!!!!!
All the ones that I've payed attention to, do. I'd never noticed it until I started looking......
  #15 (permalink)
Old 05-08-2009, 08:28 AM
Cool, thanks for all your help on this! What do I have to do to get the mirrors to work?
  #16 (permalink)
Old 05-08-2009, 08:31 AM
BigKid BigKid is offline
Nice conversion, very nice write up with the pics. It will def help lots of guys on here.
  #17 (permalink)
Old 05-08-2009, 08:38 AM
I HAVE POWAH!!!!!
You have to grind 2 aluminum alignment tabs off each mirror and then wire them up
  #18 (permalink)
Old 05-08-2009, 09:01 AM
js250 js250 is offline
how much does this cost? because a place around me said it would cost 1500.00 for parts and install. is that to high
  #19 (permalink)
Old 05-08-2009, 11:18 AM
I got everything for $500 but I still need to get the bumper painted.
  #20 (permalink)
Old 05-13-2009, 08:31 AM
no1hedberg no1hedberg is offline
Ok guys, sorry it took so long, but here are pictures of the brackets I made. Hope you weren't expecting anything too elaborate.
This is laying under the passenger side looking up. Headlight it out btw.
I used 3/16 x 1" flat bar. I put an angled 90 degree bend, and drilled a hole. I took out the bolt holding the bumper cover nearest the wheel opening, and the big one holding inner fender. I bolted the bracket to the bumper using the bolt I just took out of the bumper. I pulled in the bumper corner where I wanted it to line up. Then marked the other end of the bracket where I need the hole to be drilled. I made it slightly closer than necessary. You can always make the hole bigger, but not smaller. Bolt it together and that's it. Lines up great.
Any more questions let me know.
