Air horns install - Ford Powerstroke Diesel Forum
Old 01-14-2007, 04:39 PM
Powerstrokin'
Guest
Posts: n/a
Air horns install
I nstalled air horns on my early 99. I want to operate them from the stock horn switch in the truck. I found the location of the horn but have some questions:
how in the world do you get to the connector or
where do the wires run into the fender.
I appreciate any suggestions or shortcuts to access the connector or the wiring harness. Thanks.
Rob
Old 01-14-2007, 04:42 PM
The Fat Mod
Not sure how to answer your question, but I want to see some pics once you get done, that sounds sweet, in more ways than one
Old 01-14-2007, 04:46 PM
Powerstrokin'
Guest
Posts: n/a
I hid them behind my grill. You actually gotta look hard to see them.
Rob
Old 01-14-2007, 04:49 PM
Desert Shield/Storm Vet
Rodslinger just installed new horns and wired them to the switch send him a pm or maybe he will see this post and help ya out.
Old 01-14-2007, 05:12 PM
quick question....does it matter if u mount the horns facing forward or backward..i mounted them backward to try to keep the road dirt and rain outta them for the most part..i think it would sound better facing the front though,i jus dont want the horns to get messed up prematurely i got mine next to the spare tire under the bed with the compressor and tank inside the tool box
Old 01-14-2007, 05:23 PM
The Fat Mod
If you have a quality set, it should not matter, we run them on all of our emergency vehicles facing the front, and we dont have any problems out of them.
Old 01-14-2007, 05:30 PM
thats tru..maybe ill get more to face the front
sry bout the
Old 01-14-2007, 06:06 PM
Semi trucks face them forward. Usually with caps on them. Much louder without. I have had them freeze up in the winter with a heavy snow storm without the caps.
Old 01-15-2007, 05:56 AM
Gun Nut
Yeah Ponyboy installed mine the other day for me at our wrenching get together. Let me PM him and direct him to the thread. I'm sure he can help answer that.
Old 01-15-2007, 06:02 AM
Send a message via ICQ to ponyboy Send a message via AIM to ponyboy Send a message via Yahoo to ponyboy
Rob
Sent you a PM as well.
I just installed air horns in Rodslingers truck this weekend.
First off the horn was hard to find, but I did locate it. I looked at the color wires that were going to it. One was yellow with a green stripe. I open the wire harness at the firewall and looked for that wire. Once found I spliced there
