Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Exterior Discussion
Old 01-11-2007, 05:44 PM
badass88gt badass88gt is offline
01 platinum park light cowling
i just bought an 01 psd supercrew platinum edition, not ure what its called, but there is a park light visor bar on the cab, and it is on verry tight, but still makes a verry loud squeeking noise while driving from the wind. Are there anythings i can do to fix it, new seals, ect? Any suggestions would help, if i were to take it off, whats under it?
lmk
thanks
adam
Old 01-11-2007, 05:51 PM
lmk
thanks
adam
ANY HELP WOULD BE APPRECIATED
Old 01-11-2007, 05:53 PM
mschn99 mschn99 is offline
Banished
PM the member Maintain...he has a platinum too and had a similar issue
Old 01-11-2007, 05:58 PM
Thanks, Will Do
Old 01-13-2007, 01:49 AM
Maintain Maintain is online now
13.0 @ 102
Send a message via AIM to Maintain
I responded to your PM but I'm a little better now.
If you take it off there is a bracket underneath there. It's on there pretty good and you'll have to repaint the roof and also plug the 3/4" hole or so in the roof if you take it off. My suggestion would be either figure out why it's squeaking or remove it, repaint the roof. It's just a PIA to me, so I took it off and left the ugly bracket on but no one notices but me. You'll also most likely have to use some sort of sealant IE RTV if you do take it off to keep water from getting in and running down the Apillar onto your GEM module. This happened to me, and made the truck do all kinds of funky things. Once it dried out though I was alright.
hope this helps, any other questions you can PM me .
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
