What is factory wheel specs on a 2002 F250? - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By SJB
post #1 of 7 Old 04-17-2014, 11:58 AM Thread Starter
SJB
SJB's Avatar
Quoted: 2 Post(s)
I was curious what the specs are on the factory 16" wheels of a 2002 F250? I tried doing some searching on here, but wasn't having much luck.
Width?
Offset?
Backspacing?
2002 F250 XLT CC 4x4
- Isspro EV gauges (Pyro, Trans temp, Boost)
- Walker BTM Muffler
- 6.0 Liter Transmission Cooler
- '08 Kool-Vue tow mirrors
- Tuff Country 2.5" leveling kit 22962KN
- Factory F350 blocks in the rear
- Readylift 67-2094UB u-bolt kit for the rear
- Moto Metal 970 18x10's w/ -24 offset
- Cooper Discoverer S/T Maxx 295/70-18's
SJB is offline
post #2 of 7 Old 04-19-2014, 11:06 AM
alaskan155's Avatar
Quoted: 65 Post(s)
16x7" not sure on the backspacing maybe 5"(maybe)
either way max tire most tire shops will install is 285/75/16 or 295s
there also the metric bolt that only ford runs, 8x170mm vs the old 8x6.5" that chevy and dodge use(and the obs fords)
2002 F250 7.3/JW Tow master 4r100 212k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles, Redhead steering box
alaskan155 is offline
post #3 of 7 Old 04-22-2014, 02:46 PM Thread Starter
SJB
SJB's Avatar
Quoted: 2 Post(s)
Thanks for the information. Does anybody know the factory wheel backspacing for sure?
SJB is offline
post #4 of 7 Old 04-22-2014, 04:14 PM
7.3pwrstrke's Avatar
I had 315/75/16 on my stock 16x7s.
Somewhere online said +6mm
2003 F250 Lariat 7.3 160k
3" leveling kit, 22x14 Moto Metal 962, 33x12.50 Toyo MT, 2" wheel spacers
Harley heads, 08+ mirrors, 08+ taillights, LED switchbacks, HIDs, 20" LED light bar
DP Tuner, 4" turbo back (dumped before rear passenger tire), 6637 intake, Glowshift gauges
7.3pwrstrke is offline
post #5 of 7 Old 04-22-2014, 08:57 PM Thread Starter
SJB
SJB's Avatar
Quoted: 2 Post(s)
That would be the offset which would equate to about + 1/4". So if I'm understanding the offset/backspacing correctly: The centerline of a 7" wide wheel would be 3.5". Add 1/4" for the +6 mm offset, and you have a wheel with 3.75" backspacing. Correct me if I'm wrong here....?
SJB is offline
post #6 of 7 Old 04-23-2014, 04:19 AM
Sounds about right to me.
Most 12" wide rims are -44mm offset, so 44x0.0393 = 1.75
6 - 1.75 = 4.25 and I'm pretty sure that's the backspacing on most 12" wheels
post #7 of 7 Old 04-29-2014, 11:39 AM Thread Starter
SJB
SJB's Avatar
Quoted: 2 Post(s)
Well, I was wrong in my calculations. I did some more research and found that you have to add about 1" width to the advertised wheel width when you measure backspacing. Advertised wheel width measures from the inner lip of the rim where the tire makes contact only. For overall width, you add about 1" for total width (1/2" for each outer lip).
So the stock 7" wheel would actually have a certerline of 4" (8" overall width). Offset is +6mm (~ 1/4"). So backspacing would be 4" for centerline + the 1/4" positive offset. So backspacing would be 4 1/4". Front spacing towards the outside of the truck would be ~ 3 3/4". So if you are looking to buy new, aftermarket wheels you can compare how far they would stick out from the 3 3/4" front spaced stock wheels.
This is a good video explanation of offset and back spacing taking into account (the advertised and actual width of the wheel).
7.3pwrstrke likes this.
SJB is offline
