LED Light Bar Mounted! - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 14 Old 04-14-2014, 08:57 AM Thread Starter
Got the LED light bar mounted in the bumper this weekend! Love the sleek hidden look and holy crap is it bright! It's a 20" bar from Trail Worthy Fab. Great quality on the bar and the wiring harness, all are super tough and weatherproof. Mounted with KD Fabworks brackets.
@Ty_schilly likes this.
E99 with 99.5 engine (from factory) ECLB. ZF6. 6637 intake. 4" MBRP exhaust. PHP Hydra. Auto meter Ultra Lite II gauges. 5" lift on 35" BFG A/T's. '05 Harley lights. 20" LED bar in bumper.
shaggy99 is offline
post #2 of 14 Old 04-14-2014, 06:03 PM
Mexfdmnb's Avatar
Wow looks real nice good substitute for the factory fogs .mind throwing some pics of it on at night?
[SIGPIC]2005 F-250 CCLB zf6
leveling springs, 4" turbo back 5" tip
oil filter bypass, coolant filter
deleted, studded, sinister fuel filter cap,
SCT X3, S&B CAI, blue spring,
truxedo lowpro qt bed cover,
black diamond hg,
stand pipe, dummy plugs, stc fitting, Airdog 150,
Beans Diesel sump, edge insight cts, eadge eas pyro, turbo feed line,
Turbo drain tube, mishimoto 200* t stat, WW2
CCV MOD, High idle mod, PMF traction bars, 08 diff cover, 20" led light bar
Mexfdmnb is offline
post #3 of 14 Old 04-15-2014, 06:48 AM Thread Starter
Nope, dont mind at all. I'll get some tonight. It makes the new headlights seem worthless haha.
shaggy99 is offline
post #4 of 14 Old 04-15-2014, 04:47 PM
Quoted: 3 Post(s)
I was thinking about this a couple of days ago! My only concern was rocks hitting it being that low. Looking forward to a night time picture!
2001 F-350 4x4 7.3
2015 AXIS A24 surf boat
2012 Keystone Outback Travel trailer
r33pwrd is offline
post #5 of 14 Old 04-15-2014, 05:01 PM
Feedback Score: 3 reviews
The factory foglights are in the same location, and if you order a light bar that uses a polycarbonate lens you should have no issues. Some of the cheaper chinese brand lights use glass lenses which will shatter in no time at that level.
02 F350 7.3L Lariat; DP tuner, AFE stage II intake, AFE intake manifold, dual 4" exhaust, ATS trans, Autometer gauges, Superlift 8",
38" Toyos, 20" Provo's, Amp Powersteps, 05-07 Front end Conversion, KDfabworks bumper bracket with CSI 20" LED....
kjdavis is offline
post #6 of 14 Old 04-16-2014, 07:28 AM
Quoted: 134 Post(s)
That makes no sense to me...
The Fog lights are glass, they don't break. The Glass used in a lightbar (even Chinese) is Tempered Glass ~ Very Strong! If you've had one break, how ever unlikely that might be, I don't think it's something others have to worry about.
NoRalPh is offline
post #7 of 14 Old 04-16-2014, 07:47 AM
timmyboy76's Avatar
looks bada$$...good job.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #8 of 14 Old 04-16-2014, 08:04 AM
I've personally seen quite a few of the Chinese bars with glass lenses shatter. Part of the problem is that they are completely flat and have a larger surface area than the factory fogs. It probably depends on where you live as well. Here in the PNW we have lots of rocks other stuff left over on the roads from winter.
I've never seen a broken lens on one with polycarbonate, even the Chinese ones.
kjdavis is offline
post #9 of 14 Old 04-16-2014, 08:34 AM
Quoted: 134 Post(s)
You've seen "Quite a Few"??? really....
NoRalPh is offline
post #10 of 14 Old 04-16-2014, 08:46 AM
Yes sir.....I would consider 6 bars to be quite a few compared to how many broken factory fogs and polycarbonate lenses I've seen.
I think mounted higher up the glass lenses would be just fine.
Not trying to start any debate, just wanted to point out that it should be taken into consideration when buying a light. What type of driving you will be doing and where you're located in the States because it can, and does happen.
Here's a pic of one of the lights....mounted on a GM HD truck:
kjdavis is offline
