Narrowing overall width - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-10-2014, 05:14 PM Thread Starter
I recently got a screaming deal on a flat bed that I've had my eye on for some time. The trouble is that it was built for a duramax and is a hair to narrow for old smokey. I knew this going into the deal, It did not influence the deal one way or the other.
What are my options? I've considered newer style 18's with spacers but don't think it's possible to make a 1" spacer without cutting the factory studs down. On top of that, that seems horribly expensive. Aftermarket wheels are an option but I'd rather not.
Most likely I'll keep the bed forever, the Ford.......not as confident. Modding the bed is a last resort, it has stainless goodies everywhere that I'd rather not taint.
Ideas? Suggestions?
63wagon is offline
post #2 of 7 Old 04-22-2014, 07:20 PM
Joel's Avatar
Quoted: 10 Post(s)
Run newer style 18's but only put the spacers on the front.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 7 Old 04-24-2014, 08:12 PM Thread Starter
I considered it. Would that work with the newer style hub centric wheels vs. the older lug centric? If it would work I'm not opposed to it.
63wagon is offline
post #4 of 7 Old 04-25-2014, 01:23 PM
schlutzer's Avatar
Quoted: 18 Post(s)
The SD trucks are ALL hub centric.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 7 Old 04-25-2014, 09:19 PM Thread Starter
Are you sure? I would be excited to hear that everything I read was wrong and could bolt a set of 18's right on.
63wagon is offline
post #6 of 7 Old 04-26-2014, 12:54 AM
schlutzer's Avatar
Quoted: 18 Post(s)
They are all hub centric but duallys changed to 8 x 200 bolt pattern in 05 is your truck a dually ?
If not all SRW trucks are 8 x170 and you can put newer rims on the older truck, it can be done without spacers but will rub on turns. The only change is the studs when from coarse thread to find thread in 2003 so you need to use your old lug nuts.
post #7 of 7 Old 05-09-2014, 12:22 PM
CSIPSD's Avatar
What he said...
OBS trucks are the old style... ALL SD trucks are 8x170 hub centric...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
