Will 2001 F350 headlights fit with a 2005 front clip? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-27-2014, 08:34 PM Thread Starter
7 3 Powerstroke's Avatar
So I've been thinking about doing a 2005 front clip conversion on my 01. I've already got really nice headlights, and don't want to buy new ones. My question is will they fit properly? No huge gaps or anything? They're projectors with halos, and I really don't want to get rid of them.
2001 7.3L F350 Crew Cab, Long Bed, Dually.
Modifications: aFe Stage 2 CAI, 4" Flowmaster Exhaust with 7" Tip, XDP Compressor Wheel, Foil Delete, Glowshift MaxTow Gauges (Boost, EGT, and Pyro), and Tony Wildman 6 Position Chip.
7 3 Powerstroke is offline
post #2 of 7 Old 03-27-2014, 09:16 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 7 Post(s)
Feedback Score: 12 reviews
Maybe. What brand of lights? Pic? Did you have to trim your header panel to make them fit?
Sent from AutoGuide.com App
Marshall
2002 F250 7.3L CCSB 4WD
Tinted | Focal speakers & 12" Kicker | CTS Insight | CNC fuel line kit | PIS 200/80's | KC38R | Nathan P3 train horns & Onboard Air
mts678 is offline
post #3 of 7 Old 03-28-2014, 07:26 PM
heisman01's Avatar
Quoted: 49 Post(s)
Yes the 99-04 lights occupy the same space the 05-07 lights do. So your aftermarkets will be fine.
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is offline
post #4 of 7 Old 03-28-2014, 08:20 PM
alaskan155's Avatar
Quoted: 60 Post(s)
But you have to use the 99 to 04 support so you will have to mount the bottom of the 05 grill using zipties or etc.
2002 F250 7.3/JW Tow master 4r100 206k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #5 of 7 Old 03-29-2014, 05:43 AM Thread Starter
They're Spyders I believe, and I did have to trim the header panel to make them fit. I guess my main worry was the way they would match up with the grill, doesn't look as rounded as my 01, but I guess that's just me.
post #6 of 7 Old 03-29-2014, 06:59 PM
dieselcrawler's Avatar
Quoted: 23 Post(s)
The 99-04 headlights and 05-07 headlights have the same contours and shapes as far as fitment to grills fenders and bumpers go. No issues there. Header panel to grill fitment is a minor issue, one easily solved with a few unseen zip ties.
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #7 of 7 Old 03-29-2014, 08:26 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 331 Post(s)
I cut the header panel when i do a conversion. The 99-04 panel won't let the light recess enough so you have to cut out quite a bit to make it fit. When i'm done the 05 light bolts up like they would in an 05. 2 screws on top, 2 on bottom.
@loxdce
LoxDiesel is offline
