02 with 2012 Tailgate Backup/Reverse Cam - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-17-2014, 08:44 AM Thread Starter
TPlatt's Avatar
When I recently bought my 02, I had seen where he upgraded the tailgate to that of a 2012. It has te camera and I went ahead and threw my kenwood ddx419 head unit in that I had laying around. I cut the plug off the camera on the tailgate and tried to run the wires myself. I taped into the passenger side reverse light for power and ground and attempted to run te video+/- wires up the frame and into my radio. I spliced into an RCA cable I had. Plugged it up and I got nothing. No picture the screen doesn't even change in reverse but then I noticed a purple wire coming from my head unit that says reverse cam. What needs to be hooked up to get this bad boy functioning? If anyone can lay me out the schematic for the camera and head unit that would be amazing. Looked everywhere last few days but I keep getting stuck at dead ends. And and FYI my camera wires don't have a brown set up. Thanks guys!
2002 F-250 XLT. TS 6 Pos. Chip, AFE Magnum Force Stage II Cold Air Intake, 5" Exhaust from turbo back. 07' Headlights, Billet Grille, 2012 Tailgate, Ranchhand Rear Bumper, 6" lift, 4x Infinity Kappas, JBL GT5-2402BR, A lot more to come.
TPlatt is offline
post #2 of 11 Old 03-17-2014, 11:58 AM
StrokinAlaska's Avatar
You need to tie your deck reverse wire to the cars reverse wire. The the rca end or the radio or plug(forget which one the Kenwood has) will need to be ran to your camera. I'll try to get a wiring diagram of the factory setup from ford.you'll have to cut open the RCA end and wire it up to the camera. Thin wires so be careful!
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
The Following User Says Thank You to StrokinAlaska For This Useful Post:
TPlatt (03-25-2014)
post #3 of 11 Old 03-17-2014, 11:59 AM
Black pink hbehind your fuse box behind the knee board is reverse signal
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
post #4 of 11 Old 03-17-2014, 01:18 PM Thread Starter
TPlatt's Avatar
Thanks guys for this info. I already dd the RCA fab. Although later I'll switch it out with a RCA line level converter. Seems cleaner that way. And a schematic would be awesome. Thank you. Because everywhere else says brown color is incorporated for the camera but there are no wires with brown even on it.
TPlatt is offline
post #5 of 11 Old 03-17-2014, 06:56 PM Thread Starter
TPlatt's Avatar
I connected all the wires and nothing. I'm lost and confused about this one guys.
Edit: never mind just drove to walgreens and it worked perfectly. A little interference but not much. This weekend I will shield it with aluminum tape. Thanks for all the help guys.
TPlatt is offline
post #6 of 11 Old 03-18-2014, 09:30 AM
Some rca's will have the aluminum foil in it as a shield that needs to be connected , or an extra wire. That needs to be hooked up, but glad you got her figured out!
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
post #7 of 11 Old 03-25-2014, 04:59 AM
ZackMicF's Avatar
Quoted: 27 Post(s)
lets see some pics of the tailgate and how it looks on your stereo!!
ZackMicF is offline
post #8 of 11 Old 03-25-2014, 09:02 AM Thread Starter
TPlatt's Avatar
ok, I should be able to post some tonight once I get off duty. This last weekend was really busy for me so I haven't had the change to shield the wires yet.
TPlatt is offline
post #9 of 11 Old 03-25-2014, 01:23 PM
ZackMicF's Avatar
Quoted: 27 Post(s)
off duty? where are you stationed at?
was this tailgate on the truck when you bough it?
im looking to do the samething, its just these tail gates with the cameras are like $1500 and up, well on ebay
ZackMicF is offline
post #10 of 11 Old 03-25-2014, 09:51 PM Thread Starter
TPlatt's Avatar
I bought it with the tailgate on there already. Check here sometime this week. I'll post a write up on the first post. I gotta use the laptop to post some pics though.
I'm stationed at fort bliss
TPlatt is offline
