2005 Grill Compatibility With 7.3 ABR Front Bumper - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-16-2014, 01:20 PM Thread Starter
Austen's Avatar
Quoted: 31 Post(s)
Quick question.
I am planning on installing an '05-07 grill on my early '99. I realize that to install an '05-07 grill with the stock 7.3 bumper, the grill needs to be shaved down unless you run the newer style 6.0 bumper that is made for it.
In my case, have an ARB front bumper on my truck and looking below the stock grill, there is plenty of room to spare and nothing that I can see that would interfere with the taller '05-07 grill.
Because of this, am I correct in presuming that the stock '05-07 grill with bolt right up and not need to be shaved?
Thanks!
05-07 FORD PICKUP SUPER DUTY 05 EXCURSION GRILLE PRIMED BLACK HONEYCOMB INSERTS
08/98 CCSB l 7.3 l ZF6 l TW tuned l 38R turbo l Deleted EBPV l Bellowed up-pipes l FRX l HPX l OCR l Isspro gauges l 99.5 PCM l 6637 w/ K&N intake duct l 4" MBRB straight pipe w/ axle dump l 6" suspension lift l 37" Toyo MTs l 17" KMC Strike rims l ARB front bumper l HNC rear bumper l bedliner'd rockers l Bushwacker flares l custom cab guard l '08 tailgate l PIAA fog lights l Recon tail lights l B&W hitch l air shocks l Pioneer stereo
Austen is offline
post #2 of 5 Old 03-16-2014, 02:43 PM
MSTR-P's Avatar
Perhaps I am not reading it right...but seems to me that price is just for the inserts. Good Luck!
'03 7.3 - Stock!
MSTR-P is offline
post #3 of 5 Old 03-16-2014, 02:51 PM Thread Starter
Austen's Avatar
Quoted: 31 Post(s)
Good catch...
It looks like this is something that would work instead.
2005 07 Ford Super Duty Header Panel Grille Blk Honeycomb Headlight w Blk Bezel | eBay
Austen is offline
post #4 of 5 Old 03-16-2014, 03:21 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
No the first one was the whole grille. The second was a grille headlight combo.
As to the original question that depends on the gap measurement between the original grille and ARB bumper. Without that its hard to say
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 5 Old 03-20-2014, 11:28 AM
7.3pwrstrke's Avatar
What's the chance you know someone with an 05-07 f250/350? If you do, it's as simple as 4 bolts and 4 clips.
2003 F250 Lariat 7.3 160k
3" leveling kit, 22x14 Moto Metal 962, 33x12.50 Toyo MT, 2" wheel spacers
Harley heads, 08+ mirrors, 08+ taillights, LED switchbacks, HIDs, 20" LED light bar
DP Tuner, 4" turbo back (dumped before rear passenger tire), 6637 intake, Glowshift gauges
7.3pwrstrke is offline
