Keypad Lock? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-14-2014, 02:31 AM Thread Starter
GORILLA BE STROKINNN's Avatar
Quoted: 2 Post(s)
Keypad Lock?
I have an '03 F-350 Lariat, has anyone out there ever installed a keypad lock on one of these trucks? If so how hard was it? Already have the lock misinterpreted that it was a stick on lock... and since I already ordered it I figured "Why The HELL Not". Any feedback would be amazing and let me know what you think?
I'll take my older diesel over your brand new gas burner any day of the week...
GORILLA BE STROKINNN is offline
post #2 of 5 Old 03-25-2014, 01:01 PM
Stroker7.3's Avatar
Ford sells wireless stick on keypad locks in case you wanted an easy way out, jsut programmed to your key fob frequency
2000 FORD F250 SUPERDUTY
Stroker7.3 is offline
post #3 of 5 Old 03-25-2014, 03:56 PM Thread Starter
Quoted: 2 Post(s)
True, I made a mistake and ordered the wrong one.... FML but at the same time I work near an airport and the keyless doesn't always work because of the radars there interfere. As much as the easy way out would be nice I almost want to just go with what I have. I guess the first step is to pull the door apart from the inside and see if it is wired for the keypad, if not I guess the next step is to find out if Ford makes a wire harness or if I have to manufacture one myself...
post #4 of 5 Old 06-16-2014, 06:15 PM
Sorry to revive a thread from the dead but wanted to chime in incase you haven't already done the work. My truck shipped with a code card in the manual, a code printed on the GEM, and an empty plug (populated with pins) where the door keypad would connect. I wired up a harness and the keypad did not respond. Spoke with my service manager at the stealership who has always supported my tinkering, and he claims that even with the hardware present, the keypad will not function since the vehicle shipped without a keypad. He claimed the only way to enable it would be to flash the GEM with an image from a vehicle with a keypad, or replace it with a GEM from a vehicle with a keypad. He claimed that a GEM (or flash) from a different vehicle would cause communication issues. I gave up and built a controller to take in the input of the keypad and send a signal to the lock switch. Hope you have some luck! Let us know if you have success.
TomPethtel is offline
post #5 of 5 Old 06-16-2014, 09:01 PM Thread Starter
Quoted: 2 Post(s)
Damnit. Well I haven't started yet. Other things have been on my mind. But wouldn't the communication issues only be with the keyless entry remotes?
