Kool vue mirrors- can't adjust up & down! - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-11-2014, 04:26 PM Thread Starter
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 7 Post(s)
Feedback Score: 12 reviews
Just finished installing the kool vue mirrors, fit great, glass doesn't shake or vibrate.
Driver side connection match up as in the how to stickie, I can move left to right no problem, but no up and down. Same with the passenger side, no up and down adjusting.
Anybody have the same problem and know the fix? There's some extra wires as well in the loom and not sure what them are for
Sent from AutoGuide.com App
Marshall
2002 F250 7.3L CCSB 4WD
Tinted | Focal speakers & 12" Kicker | CTS Insight | CNC fuel line kit | PIS 200/80's | KC38R | Nathan P3 train horns & Onboard Air
mts678 is offline
post #2 of 9 Old 03-11-2014, 04:54 PM
ZMANN's Avatar
Quoted: 1346 Post(s)
i would bust out the tester
but those how too articles looked pretty detailed did u double check your install ?
We Miss you Ronnie
ZMANN is offline
post #3 of 9 Old 03-11-2014, 04:56 PM Thread Starter
mts678's Avatar
Quoted: 7 Post(s)
Yea they're for OEM mirrors and these are aftermarket. After searching extensively, it seems this is a common problem and nobody has really updated the threads with the fix. Can't find a wire diagram anywhere on the net.. Just emailed kool vue I'll see what they say.
Marshall
mts678 is offline
post #4 of 9 Old 03-11-2014, 05:26 PM
ZMANN's Avatar
i posted in the other thread
you must have seen this thread ? i was going to use it when I get my mirrors some day
Wiring 2008+ Power Fold/Telescope Mirrors into 1999-2007 SD Trucks - The OEM way
We Miss you Ronnie
ZMANN is offline
post #5 of 9 Old 03-11-2014, 06:15 PM
Quoted: 7 Post(s)
Did your stock mirrors have the same issue? I don't know if they are the same brand but when I installed my 08+ mirrors from A1, I couldn't move them down or the left. I ordered a new switch from LMC and now everything works.
Will335i is offline
post #6 of 9 Old 03-11-2014, 06:16 PM Thread Starter
mts678's Avatar
Quoted: 7 Post(s)
Thanks zman. I'm reading through the threads
Marshall
mts678 is offline
post #7 of 9 Old 03-11-2014, 06:17 PM Thread Starter
mts678's Avatar
Quoted: 7 Post(s)
No I didn't, the up down left and right worked just fine. I'll just order one anyway, after seeing many threads on different forums, seems a new switch is the fix.
Marshall
mts678 is offline
post #8 of 9 Old 03-14-2014, 09:49 AM
1997PSD's Avatar
Quoted: 2 Post(s)
A1 auto has a conversion harness. Might be a little late for that, but if not its definitely a good option for a clean install.
2000 F-250 XLT
Twisted Diesel Level II 4R100 w/ V10 Cooler
TS 6 Position w/ PHP Tunes.
4 inch turbo back straight pipe.
Wicked Wheel 2
18in XD's wrapped in 35in Toyo Open Country M/Ts
3 inch PMF shackles w/ Ford X-codes.
Re-routed CCV
Red Head Steering Gear
Isspro A-pillar Gauges.
7 inch pioneer touch screen.
'07 grille and Morimoto Retro'd headlights
'08 side mirrors.
Ranch Hand bumper.
1997PSD is offline
post #9 of 9 Old 02-27-2016, 09:37 AM
I am having the same up/down issue after installing 08+ tow mirrors on my 05. Everything else works and wiring appears correct from pinout diagrams I have. Does anyone know a solution?
R1Racer is offline
