2000 F350 bed delete or cab chassis - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-10-2014, 01:44 PM Thread Starter
I know my truck did not come with a bed on it new. There is a utility bed on it. I am wanting to put a regular bed on it. How can I tell if the truck was a cab chassis or ordered bed delete?
2000 Big Rig is offline
post #2 of 5 Old 03-11-2014, 09:45 PM
Eco Taxi's Avatar
My cab chassis has the fuel tank in the rear between the frame rails whereas a regular truck has the tank on the outside of the frame rail .... Someone correct me if I'm wrong
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #3 of 5 Old 03-12-2014, 07:50 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
Yer on the right track. Top of frame rails will be straight, and measure 9' from back of cab to end of frame if it's cab and chassis truck. If its 8' long, and top humps up over the rear axle, and has mid-ship fuel tank, you can drop a factory bed right on...
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #4 of 5 Old 03-12-2014, 07:53 AM
Quoted: 23 Post(s)
Cab to axle is 54" for std 8' bed, 60" for 9' cab n chassis, 84" for 11'
Greg
Semper Paratus
post #5 of 5 Old 03-12-2014, 08:03 AM
Quoted: 23 Post(s)
Example of straight frame. This is an 11' cab n chassis truck I'm rebuilding at work.
Greg
Semper Paratus
