2005-2007 front upgrade Q&A - Ford Powerstroke Diesel Forum
Old 11-14-2008, 03:46 AM
I have a 2000 F350 and am going to a 05-07 front end.. Here is a list of parts I have sourced for the conversion.. If anyone thinks of something else chime in..
Ford OEM headlights for 2005.
Ford OEM Grill for 2005.
Ford OEM headlight panel.
Ford OEM front bumper.
Ford fog lights and brackets.
05 bumper brackets.
From what I found in the forum this should all mount right up...
Old 11-14-2008, 05:14 AM
Wiring harness or pigtails to wire up the headlamps.
05-07 heads use a H13 bulb and the 99-04 uses a 9007 bulb.
There are a variety of plug and play pigtails and harnesses to use.
Old 11-14-2008, 06:20 AM
You may need an adapter for the corner marker light too.
Old 11-14-2008, 09:16 AM
I didnt list that but they are on the headlights... Thanks for listing...Did yours bolt right up??? Another question will the 08+ bumper fit a 05-07??
Old 11-14-2008, 09:22 AM
Send a message via AIM to AaronATX
i doubt it.. i'm sure you could make it but it would probably look funny..
