Headlights - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-27-2014, 04:22 PM Thread Starter
Headlights
I ordered some headlights from ebay and it said they take h1 bulbs for the high and low beam but that would be a different bulb for each not a high/low single bulb. Has anyone bought theseHeadlights-imageuploadedbyag-free1393550517.801074.jpg
bberry09 is offline
post #2 of 4 Old 02-27-2014, 09:04 PM
Solid98's Avatar
Quoted: 9 Post(s)
I just ripped a set of those out of my truck. They were on it when I bought it. The driver side was pointing out towards Pluto and there was no way to adjust it. It does use a different bulb for high and low beams.
The ones I had might not be the same ones on ebay but they look identical. Ugly m-f'ers. The 03 clear lens stock headlights I bought from A1 look a million times better. Light better too.
Just to clarify, the aftermarket lights I had had no adjustment to them. They used the two screws that had held the turn signals on and the two studs at the very top held in with those stupid little spring clips. The plastic standoffs at the top were already screwed out as far as they would go and the light was still pointed at the stoplights. Luckily, they reuse the turn signal and marker light sockets and just plug into the stock headlamp socket so they don't require cutting any wires.
01 F250 XL Ex Cab: RIP 12-15-2013
1999 F250 XLT 4X4 auto, Bully Dog 5" straight pipe, rest stock.
Solid98 is offline
post #3 of 4 Old 02-27-2014, 09:16 PM
7 3 Powerstroke's Avatar
Mine use different bulbs, hi beams are halogen and low beams are HIDs, not sure on the sizes though. Mine adjusted perfectly with just the screw things on the top where you put the clips on, they're aimed perfectly.
2001 7.3L F350 Crew Cab, Long Bed, Dually.
Modifications: aFe Stage 2 CAI, 4" Flowmaster Exhaust with 7" Tip, XDP Compressor Wheel, Foil Delete, Glowshift MaxTow Gauges (Boost, EGT, and Pyro), and Tony Wildman 6 Position Chip.
7 3 Powerstroke is offline
post #4 of 4 Old 02-28-2014, 07:03 AM
Quoted: 169 Post(s)
Feedback Score: 3 reviews
I have those too, they aim fine...
NoRalPh is offline
