Installed Hids now truck want run - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-22-2014, 04:34 PM Thread Starter
White7.3stroker's Avatar
Send a message via AIM to White7.3stroker
Got my hids today from DDM Tuning and installed the and my truck wouldn't hardly run even with the lights off..So I cut it off removed my DP tuner no change sounds like it's only running on 4 cylinders and when you cut the lights on the truck dies..any ideas?
________________________ Early 1999 Crew Cab Long Bed
zoodad mod,Fog light mod,08tailgate,Harley lights,04 mirrors,built Tranny,diy intake,5" turbo back exhaust,DP tuner,glowshift guages,6"lift 20x12 fuel Octanes,33x12.50 Mud Grapplers...soon HID's,Led reverse lights,New tires lol,
White7.3stroker is offline
post #2 of 5 Old 02-23-2014, 06:21 AM
The truck decided that it doesn't want to look like some kid's dodge, and cares too much about blinding other drivers at night.
Maybe if you put some truck nuts on the rear bumper, and bulldog it. Might get it to run then.
'97 XLT F-350 Crew Cab LB, 240,000 miles, 20x10 MB Rocker Rims, with TOYO 35x12.50x20, tool box, Swamps TS tuner, MBRP exhaust S&B Intake, Auto Meter gauges.
xjaddiction is offline
post #3 of 5 Old 02-23-2014, 07:11 AM
Term3's Avatar
Or go the cheaper route and weld nuts on the end of two chains to hang off your back bumper. I'd use the 2" ones we use at work, you may want to use a couple 1/2" ones.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #4 of 5 Old 02-23-2014, 07:24 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Disconnect the lights power from the battery see if it goes away
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 5 Old 02-23-2014, 08:15 AM Thread Starter
Okay I will try that thanks Dave
