Ranch hand 99-04 vs 05-07 - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-22-2014, 03:48 PM Thread Starter
Wilson7397's Avatar
I recently picked up a ranchhand . The part number is for a 05-07 superduty. I'd like to put it on an 01.
Does anyone know why it's a different part # . I couldn't imagine it being anything majorRanch hand 99-04 vs 05-07-imageuploadedbyautoguide1393116474.039510.jpg
Sent from AutoGuide.com App
Wilson7397 is offline
post #2 of 6 Old 02-22-2014, 04:34 PM
scagle1's Avatar
According to a ranch hand I had as well as a road armor , the mounting bracket is the same. The only thing different will be you will have a slightly larger gap under your grill as the 05^ are a bit longer than the earlier years. On an aftermarket bumper that gap is awfully hard to notice as they leave room anyway. So in theory , it makes for an easy swap to a newer grill without any trimming as well...
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #3 of 6 Old 02-23-2014, 08:35 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
If I bought one I would want tje 05-07 so I could use an uncut 05-07 grill.
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #4 of 6 Old 03-06-2014, 01:48 PM
the1laf's Avatar
It has the gap for the larger grille, and the bar that runs around between the headlight and turn signal is higher..
I have the 99-04 version and that bar runs right through the middle of my turn signal reflector because I swapped to the 05 headlights.
2000 F-350 Lariat CCLB w. 335,000+ Mi
Tymar intake, Straight 4", 6.0 Intercooler, IDP Competition Fuel System, AC's, SB SD Clutch, ZF6 Short Shift Kit
Gearhead Tunes, Swamps IDM, Snow Performance Water/Meth, Isspro Performax Gauges & 08 Black Leather Seats
05 Harley's, Smoked tails, Weld Racing Sidewinder Wheels
Fried Piston, Re-building engine
330 RWHP Fuel Only - 363 RWHP w. Meth
Broke College kid... Eating Ramon to save for truck parts..
the1laf is offline
post #5 of 6 Old 03-06-2014, 05:59 PM
Quoted: 23 Post(s)
Headlight/turn signal size is the same on both... if it covers the turn signal lens on one it will do the same on the other. Sounds like something is mounted wrong, bumper is too high maybe?
Greg
Semper Paratus
post #6 of 6 Old 03-06-2014, 06:14 PM
the1laf's Avatar
Look at this bar compared to the OP's.
The angle I took this at doesn't show it, but this runs right in the middle of my turn signal, the 05-07 bumper has this bar about 1.5" higher..
*Not that it would make any difference during an install, I just wanted to let the OP know the difference between the two.
the1laf is offline
