Cab Light Template??? - Ford Powerstroke Diesel Forum
Old 11-01-2008, 07:59 AM
Ole White
I am going to buy some cab lights here soon and have been looking everywere for a template of were to drill the holes in the roof anyone have a link to one????
Thanks in advance Taylor
Old 11-01-2008, 10:04 AM
Ole White
Anyone???
Old 11-01-2008, 10:06 AM
Rob Rob is offline
i got mine coming in today sometime.. i am also looking for a template.. if i find one ill let you know.
Old 11-01-2008, 10:24 AM
I installed my Recon LED Kit this past week. Never could find any template's really.
The best i could find were these instructions
Motoman's Madness
But those are the instructions the Recon sends with there kits
I followed those for the most part, but changed a few things more to my liking.
They turned out good
I definitely recommend getting the factory wiring harness, as it makes the install a whole lot cleaner, and the wiring part a whole lot easier
If you have the Recon kit those, you'll have to splice the REcon connectors onto the OEM harness.
Old 11-01-2008, 10:35 AM
Ole White
Thanks for the info
I swear I've seen a template somewhere before though
Old 11-01-2008, 10:54 AM
You don't really need a template, I didn't use one. Do you have a buddy who has the same truck with cab lights? That's what I did used his for reference.
Old 11-01-2008, 11:14 AM
Ole White
That's the problem out of all our works and my buddies none of the trucks have Cab Lights
Old 11-01-2008, 04:08 PM
Lifetime Premium Member
When I was doing truck accessory installations,we would use a sun-visor or moon-visor for a truck with factory cab lights.Might want to check the lund website,they are the ones we used for the visors.
Old 11-01-2008, 04:25 PM
International Threat
Check the tech files guys, jeez!!! LMAOOOOOOOOOOo
Old 11-01-2008, 10:21 PM
When I installed my cab lights, I just centered the light fixtures between the roof ridges (or whatever you call them) for side to side placement. However, I think only the crew cabs have these ridges but I'm not sure. As far as front to back placement, I just one of the light fixtures to determine. Distance from top edge of windshield weatherstripping to front edge of light fixtures is the length of a cab light fixture. At least they appear to be placed just right when compared to a stock cab light setup. I'm pleased w/ the way they turned out. Hope this helps, rather than confuses! Here's how mine looks.
