| 99-03 7.3L Exterior Discussion Body and Accessories Talk |
sticky stuff removal..
When I bought my truck it had that stick on chrome rocker panel trim. I didn't like it so I peeled it off, as well the other door trim.
That left me with large sections of foam tape still stuck there.. so I used a heat gun and plastic putty knife. NOW.. Im stuck with all the little residue, the sticky crap and little parts the putty knife couldn't scrape.. Adhesive remover doesn't really appear to be doing anything-though its cheap stuff, so maybe that has something to do with it? SO-ideas? How do I get all that off and get it nice and clean? How bout goo gone? Heat and goo gone? Im at a loss.. it really doesn't want to come off. It's below freezing out there too.. soo.. keep that in mind. |
I used heat and thumbs. You are going to have blisters but you can roll it off with your thumb. It is tedious but it works!
Go Be Gone or alcohol
I have always had good luck 3M adhesive remover. Some other stuff I have picked up at the Dollar store of all places, it's n a clear white spray bottle... it's called Awesome Cleaner, it’s like a buck 50 or so and that stuff will amaze you at what it will cut through, hasn’t hurt any paint or any finish I have ever used it on – Good Luck and congrats on the new truck
WD40...it will fix anything. Seriously, try it!
try kent products acrysol. It is the stuff!!
It sounds like im on the right track..
that stuff is really on there though! Im impressed. I don't know if its because its cold outside or what.. but its on there good. Thanks guys. |
alcohol, or goo be gone. it works wonders!!!!
this is what you need to use..also use a hair dryer to soften it up.It will suprise you how easy it becomes to remove it.
Well I finally got it all off today. It took the heat gun, goo gone, and a lot of elbow grease. Since it was 20 degrees out there it was nice to have the heat gun; just shoot a little heat on the hands when they go numb. Still needs some clay bar action and wax.. but its too cold.
Thanks for the help guys! |
