2003 Clear Headlamps from Rock Auto - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-04-2014, 02:04 PM Thread Starter
I've been researching the replacement of my dingy 2000 F250 ribbed headlamps and I think the easiest solution I've seen is to replace them with the clear headlamps from a 2003 F250. This looks like a direct "no mod" replacement. Rock Auto has them at pretty reasonable prices, about $58 a pair. At Rock Auto, you can also get the same part as "CAPA Certified" but the cost is almost 3 times as much. Why? I certainly understand wanting to be CAPA certified if I'm buying a body panel, but how much of a chance am I taking that the headlamps will not fit?
jlmanatee is offline
post #2 of 5 Old 02-04-2014, 02:22 PM
schlutzer's Avatar
Quoted: 18 Post(s)
I can't comment specifically on the 03 lights.
But I have an 05 header panel and 05 harley lights from rockauto and they are very good. I was worried about maybe cheaper plastic so i've clear coated the lights to make them last longer
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 5 Old 02-13-2014, 10:29 PM
jones2012's Avatar
I just did this myself. Replaced headlights and turn signals and it took 10 years off the truck. Parts were a direct fit and took less than an hour to complete.
jones2012 is offline
post #4 of 5 Old 02-14-2014, 05:27 PM
chrgd2000's Avatar
I got the clear headlights and blinker lights on ebay for $70. Fit just fine. I put a bead of clear silicone around the edges to make sure they are sealed. Sometimes aftermarket light are not sealed correctly so they build up condensation.
--7.3
chrgd2000 is offline
post #5 of 5 Old 02-15-2014, 08:41 AM
I have them for my 2000, they are a direct replacement. They look much better than the yellow ones I took off.
Bromontana is offline
