Clearance light install? - Ford Powerstroke Diesel Forum
Old 11-26-2006, 03:05 PM
Jon
Guest
Posts: n/a
Ford offers an aftermarket clearance light kit for our Super Duties and I am curious if anyone of you have ever installed it? I know it comes with a stencil but how hard is it really?
Old 11-26-2006, 03:15 PM
i think rodslinger did his himself
Old 11-26-2006, 03:22 PM
International Threat
It's not hard at all. Forget the stensil you don't really need it. My buddy did this on his 01 Ram 1500 and it came with the locations already set and all he did was drill, and install lights and wires.
I'd think it'd be cheapest to buy some clearance lights from www.AWDIRECT.com for 6 bucks each and then do the wiring yourself. So 30 bucks, and you've got clearance lights or go to the dealer (or your work in your case haha) and order their entire kit that includes plug in harness for over 100 bucks.
You can use tape to make the line across the roof, mark the holes, and drill and I suggest driilling from the outside in. You gotta drop the front of the headliner of course but you should have no problem with that.
Old 11-26-2006, 03:51 PM
Jon
Guest
Posts: n/a
Lights
I'm wanting to put clear lenses with orange bulbs. I think that would look good. I think I have Logan convinced to switch to the clear lenses with orange bulbs also.
Old 11-26-2006, 04:03 PM
Gun Nut
Brian's right - I did mine. I bought my lights and harness from the Ford house for - shoot I think about about $80.
It was a PITA just because drilling 20 some odd holes in the top of your rig REALLY sucks! Just kidding! The worst thing about the install is it better be time consuming because if it isn't you need to measure again ( ) and working around the headliner is a pain.
Old 11-26-2006, 04:48 PM
has anyone seen led's yet for these things.
Old 11-26-2006, 05:02 PM
http://www.emotoman.com/f250/lights/f250lights.htm
how to install
Old 11-26-2006, 05:12 PM
Jon
Guest
Posts: n/a
Thanks man
Thats an awesome link.
Old 11-26-2006, 05:29 PM
awdirect.com is right, they are a towing supply house, so they have tons of marker lights.....led's too i think.....the install is easy.....but just like anything on your roof(visor, antennas, sunroof) you gotta make sure to seal it very well or you'll have a wet headliner and all kinds of other problems. I would use silicone gasket maker.....its good stuff......
wes
Old 12-25-2006, 09:47 AM
This place has a ton of LED's TMI LED TECHNOLOGY: TMI Products Below
I had no idea you could get the lights so cheap from Ford. I think I'll be doing this install pretty soon. Fortunately, I've had a bit of experience with this from installing/fixing clearance lights on Peterbilts. That's good advice Wes! I typically use about a 1/4 bead of silicone around all holes and have never had a problem.
