315's. . . yes or no. . . - Ford Powerstroke Diesel Forum
View Poll Results: 315's. . . yes or no. . .
Yes 32 82.05%
No 7 17.95%
Voters: 39. You may not vote on this poll
Old 10-13-2008, 09:43 AM
I have a 2000 F350 4x4 with the leveling kit up front and I'm off to buy tires in a few hours. The 315's are just a little more then the 305's so I want them if they will fit.
315's Yes or No?
Old 10-13-2008, 09:45 AM
315s i think are what i have, and are almost 35s, they may rub, i have a 4inch lift and it looks semi tight.
Old 10-13-2008, 10:00 AM
There have been other threads and everyone says that the 315s will clear with just a leveling kit
Old 10-13-2008, 10:11 AM
I do apologize for not searching.
It's next to impossible on the phone.
Old 10-13-2008, 10:34 AM
315's should fit fine with a leveling kit. Depending on the brand - their roughly 34.5" tall and 12.5 wide.
305's are roughly 32.8 tall and 12.5 wide (again, depending on brand). I run 305's and just had a 2" add-a-leaf front and rear installed - I think it looks good with just 305's - 315's should be fine too!
Old 10-13-2008, 10:37 AM
Go 315's you wont be disapointed
Old 10-13-2008, 10:45 AM
Send a message via Yahoo to Drepka
soon as mine wear out im buying 315s, Go big or go home!!!!!
Old 10-13-2008, 11:04 AM
i have both 295's and 305's for my truck, and even with the leveling kit there's no way that 315's will work without rubbing. I suppose if you never leave the road then they'd be fine, but for any kind of articulation it would rub like crazy.
Old 10-13-2008, 11:12 AM
No off roading what so ever. It pulls my jeep to those off road places with a truck camper in the bed. That is the heaviest load she pulls.
I have 4.11s and the main goal of the bigger tires is to lower that gear ratio for winter holiday travel and that it will look freekin sweet!
The set I'm looking at is Nitto Terra Graplers.
Old 10-13-2008, 05:28 PM
35's are not well suited to a leveling lift. Go at least one size smaller. I had success in performance and looks with 285s on a leveling lift.
