Headlight conversion question - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-26-2014, 07:50 AM Thread Starter
delta99's Avatar
I have a 2000 super duty with the big, honkin' "aero" headlights. I'd like to change them out to the smaller sealed beam lights with the plastic bezels around them. Does anyone know what all I would need to do the switch as far as parts? And are the plugs the same for the bulbs, or would I have to do a little re-wiring? And does anyone have them laying around they'd like to get rid of?
I want to switch from these to these
ID:	233490   Click image for larger version
Name:	20378d1366279262-2000-f-350-super-duty-headlight-trim-removal-f350-headlight-trim.jpg
2000 F250 Super Duty, 4x4, 7.3, 6 speed manual, 4" straight exhaust, 6637 air filter, superwinch hub locks, zoodad, foil delete, AIH delete, power pedal, autometer gauges, 2.5" leveling kit, 260,000
delta99 is offline
post #2 of 10 Old 01-26-2014, 10:58 AM
Houstonvett's Avatar
The lights you want to switch over to are lights that came on the XL or base model/work truck packages. On higher trim package trucks XLT above, the aero lights came on these units. They are 2 different plug ends that aren't interchangeable, if I remember right.
The aero lights use a 9007 bulb and the XL guys are sealed beam units and are of a different a wiring configuration.
Get the Sylvania headlight restoration kit and use that on your aero lights. Makes them look brand new and it does last a very long time. Take your time when sanding and take them out of the vehicle also, when restoring the lights.
Houstonvett is offline
post #3 of 10 Old 01-29-2014, 02:54 PM
dieselcrawler's Avatar
Quoted: 23 Post(s)
Replace them with '05-'07 headlghts. I have done so on 2 of mine and its worth it. I used a relay conversion wiring harnes from GOS Racing... makes wiring pluh-n-play. Cutting the header panel can be done in about an hour... lights can be had on ebay for cheap. I used after market ones (eagle eyes was the brand) with good luck so far.
This might be easier than the old style sealed beam lights.
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #4 of 10 Old 01-29-2014, 03:23 PM Thread Starter
delta99's Avatar
I don't like the look of the 05-07 grille/headlights at all. I just painted the matte grey part of my grille black, and left the chrome. I really like how it came out, but it needs more black to make it look right. I think if I put the XL headlights on it and paint the bezels black it will give me the look I desire. I don't really care about easier. I'm willing to do the extra work to get the truck looking the way I want. Thanks for the thoughts and input. I'm just waiting for one to show up in the junk yard now.
delta99 is offline
post #5 of 10 Old 01-29-2014, 07:00 PM
Quoted: 12 Post(s)
You really want to down grade your headlight performance just for the looks of them? FYI sealed headlights are a lot more expensive to maintain since you have to replace that whole unit not just the bulb. Do what you want to your truck but doesn't make a lot of sense in my opinion.
Will335i is offline
post #6 of 10 Old 01-31-2014, 01:25 PM
the1laf's Avatar
I agree with the others, the only possible reason you could be doing this is for looks and there are many other options in that department.
Check out a write-up I did a while back..
Head to Head Headlights
2000 F-350 Lariat CCLB w. 335,000+ Mi
Tymar intake, Straight 4", 6.0 Intercooler, IDP Competition Fuel System, AC's, SB SD Clutch, ZF6 Short Shift Kit
Gearhead Tunes, Swamps IDM, Snow Performance Water/Meth, Isspro Performax Gauges & 08 Black Leather Seats
05 Harley's, Smoked tails, Weld Racing Sidewinder Wheels
Fried Piston, Re-building engine
330 RWHP Fuel Only - 363 RWHP w. Meth
Broke College kid... Eating Ramon to save for truck parts..
the1laf is offline
The Following User Says Thank You to the1laf For This Useful Post:
delta99 (02-02-2014)
post #7 of 10 Old 02-01-2014, 06:23 AM Thread Starter
delta99's Avatar
At $12 I'm not really concerned about them being "expensive." And FYI, there are drop in replacement units available which accept a lot more cheaper halogen replacement bulbs. Not really an issue for me.
Yes, as I stated in my OP, the only reason I could be doing this is for looks. Thank you for the link, you have a lot of good info there. I am now thinking of getting a set of black 02-04 headlights. Not exactly the look I want, but still better than what I have, and better performance than the sealed beams.
Thanks everyone for your thoughts and input
delta99 is offline
post #8 of 10 Old 02-01-2014, 06:29 PM
the1laf's Avatar
Sorry I didn't make myself clearer, I meant the only reason to justify that headlight is in a show truck, where performance wasn't a factor..
I'd recommend the orange for a smoked corner light while you're at it. IMHO it looks so much better.
Also I'd recommend higher wattage aftermarket replacement bulbs. Since that write-up I pulled the HID's because of the trouble they had turning on @ below zero temps and went with PIAA 85w/75w direct replacement bulbs. They're a happy medium between the HID's and stock (65w/55w) bulbs.
Glad you liked the Write-up, give me a "Thanks" if you don't mind, I'd appreciate it.
the1laf is offline
ande6009 (02-13-2014)
post #9 of 10 Old 02-01-2014, 06:33 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 369 Post(s)
The sealed beam lights have adapters on them from xlt harness to xl plugs from factory trucks just an fyi. You shouldn't have to rewire it. All u need to do is take them off the truck you're takin the lights off of
@loxdce
LoxDiesel is offline
The Following User Says Thank You to LoxDiesel For This Useful Post:
post #10 of 10 Old 02-02-2014, 07:51 AM Thread Starter
delta99's Avatar
I'm going to go with something like this
I like the stock orange marker lights. Not sure yet if I'll switch those out for smoked
And the1laf, I gave you some thanks. That was a great write up, and very helpful. Thank you!
delta99 is offline
