Lifting A Dually - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-23-2014, 08:49 PM Thread Starter
StrokinAlaska's Avatar
Lifting A Dually
I have my 99 f350 crew cab longbed dually that I would really love to lift, but like most newbies I have not much clue on what to do. I would like to do 2.5"+ but not bigger then 5.5ish. I want to use my 16's with some beefier tires, and eventually upgrade to 18s or even 20s at the biggest. I don't want to break the bank on the lift so any help and direction would be greatly appreciated. I have done 2.5 inch leveling rings on my 08 ram and was pleased but have no idea what would lift my tank how I want. Can I just do blocks in the rear (I have 2" factory now) and leafs in the front?
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
post #2 of 4 Old 01-24-2014, 11:34 AM
Quoted: 12 Post(s)
I wouldn't think that lifting a dually is any different than lifting a regular truck. I think the Tires in the rear will be the only difference. Personally I don't like blocks, I view them the same as coil spacers, I think they compromise your stability some. I don't think you could go wrong with any of the big names, Fabtec, Procomp, Skyjacker, ect.
If you do your research and spend a little money on a nice lift you will be much happier. There is a reason its call a death wobble.
Will335i is offline
post #3 of 4 Old 01-24-2014, 04:15 PM
sulltran's Avatar
Only difference is the rear u-bolts ......they are bigger on a drw because of the larger diameter axle tube. Other than that you can install a reg lift kit for srw.
sulltran is offline
post #4 of 4 Old 01-24-2014, 04:31 PM Thread Starter
I see some cheapo block kits online. 4" rear blocks and u bolts 119$ or so. Then lot of mini leaf packs to do the front. Are those just simple cheesedick lifts or what. I obviously understand the big names are better as I work in Car audio and know u are paying for the name as well as product. I just don't need anything special. I don't tow or haul anything and don't are too much about change in ride quality since Im jn a 1ton. Thanks guys
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
