flashing lights/door ajar light - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-10-2008, 10:16 PM Thread Starter
Having a problem with my 02 Excursion and I was hoping to get some insight. All of the sudden the door ajar light on the door starts flashing and the interior lights flash, the doors lock and unlock and the headlights flash. I also noticed tonight that the door locks seem to be reversed...so when I hit the lock button they unlock and when I hit the unlock button the doors lock.
I tried the cleaning the door latches with brake cleaner and lubing up...no luck. Any ideas?
Thanks in advance!
Matt
bmwguymatt is offline
post #2 of 7 Old 10-11-2008, 05:20 AM
Sounds like PATS (passive anti theft system) which is the factory alarm system on Excursions. If it has been raining recently you may have gotten water into the GEM (this was a recall). You can find out everything you would ever want to know about either by searching them.
#49
Live Tuning by Tony Wildman at TotalDieselPerformance.com
Paint and Upholstery by Chris Rayner and Eddie Wheelhouse at DetroitCustomsRods.com
whatabudro is offline
post #3 of 7 Old 10-11-2008, 08:26 AM
Powerstroke Junkie
NCHornet's Avatar
I agree with the above, when water get's in this module all sorts of wierd stuff can happen!!
NCH
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #4 of 7 Old 10-19-2008, 02:38 PM Thread Starter
Thanks for this Would the PATS system still allow the truck to start and run? It is running just fine.
post #5 of 7 Old 10-19-2008, 02:45 PM
if pats went bad truck would not run, whe gem goes bad all electrical units go hairy!!!!!! and do all crazy kind of things
diesel tech 01 is offline
post #6 of 7 Old 10-19-2008, 02:59 PM Thread Starter
Thanks. Can you tell me what GEM is. Is it something that I can replace or is it a dealer ordeal?
post #7 of 7 Old 10-19-2008, 03:22 PM
Generic Electronic Module
I'm pretty sure it has to be programmed to your truck by Ford.
#49
