Harley headlights on 99 - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-15-2014, 11:57 AM Thread Starter
strokin n smokin's Avatar
I just wanted to see if Harley headlights were direct replacements for the stock headlights? Or does something need to be modified? Thank you
1999.5 Ford F-250 4x4 CCSB Lariat.
281k.
ZF6 speed Tranny.
4 inch exhaust.
Just a grocery getter.
strokin n smokin is offline
post #2 of 6 Old 01-15-2014, 12:12 PM
scagle1's Avatar
If I'm not mistaken you have to cut the header panel. You may find a direct swap aftermarket pair , but I believe most of the newer style upgrades require trimming even on aftermarket. Plenty of writeups on it here if you choose to do it
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #3 of 6 Old 01-15-2014, 01:16 PM Thread Starter
Alright thank you. I'll look them up
281k.
ZF6 speed Tranny.
4 inch exhaust.
post #4 of 6 Old 01-15-2014, 04:29 PM
WVRidgeRunner's Avatar
I used an aftermarket set of harley lights. Made a huge difference in what I could see at night should've been done years ago. THink I pain around $160.00 and that included the harnesses to adapt to the new headlights. Had to cut the header panel to fit them. First one took 40 minutes or so, second one about 15. I used a 4.5" angle grinder for the big straight cuts and my dremel tool to connect the dots. It's not a bad saturday morning project at all and if your lights are half as bad as my 99.5s were you'll wonder why you didn't do it sooner.
1999.5 707 Conversions Super Duty 7.3 Crew Cab LB Dually 4x4 Edge Evolution, Oil HPx, Fuel FRx, tons of filters, hutched n harpooned, B&W turnover ball and 5th wheel, lotsa goodies.
WVRidgeRunner is offline
post #5 of 6 Old 01-18-2014, 07:32 PM
citizeninsane's Avatar
Garage
Here is my write up on my 99:
my 05-07 HD headlamp conversion
citizeninsane is offline
post #6 of 6 Old 01-21-2014, 05:01 PM
7.3pwrstrke's Avatar
There's TONS of write ups on this.
I just did mine a week or two ago.
Here's the cheapest I found, then just search "9007 to h13 harness" on ebay and they have them for >$10
05 07 Ford Super Duty Harley Davidson Truck Headlights Headlamp LH RH Pair Set | eBay
2003 F250 Lariat 7.3 160k
3" leveling kit, 22x14 Moto Metal 962, 33x12.50 Toyo MT, 2" wheel spacers
Harley heads, 08+ mirrors, 08+ taillights, LED switchbacks, HIDs, 20" LED light bar
DP Tuner, 4" turbo back (dumped before rear passenger tire), 6637 intake, Glowshift gauges
7.3pwrstrke is offline
