HELP: Dually bed swap???? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-13-2014, 03:55 PM Thread Starter
RJ's325ITS's Avatar
Angry HELP: Dually bed swap????
So I have a 2000 F350 dually that had a blow-out that almost destroyed the driver side of the bed..... I'm thinking of getting a used replacement bed and doing the swap my self....
Has anyone done this at HOME?????
I have a bunch of fab tools and plenty of knowledge in auto repair and work but had never changed/swapped a full size truck bed.
If you know of a video, or DIY write up please post the link, I've been looking for 2 days with nothing that little truck bed swaps, like S10, and rangers
Thank you~
Rafa,
PS: I dont have acces to a crane nor a big tree to install a pully system, all
I have is a dual car garage where the dually wont even fit
2000 F350 Dually, Bullydog GT, Straight exhaust, Riff Raff filter, front grill cut out.
RJ's325ITS is offline
post #2 of 5 Old 01-13-2014, 04:22 PM
alaskan155's Avatar
Quoted: 60 Post(s)
A couple friends is all you need(atleast 4 but 6 is recommended) or some 2x2s and blocks to block to bed up.
Ive removed midsize 8 foot beds before by myself by removing the rear bumper and sliding the back and tipping the straight up in the grass (soft) on a superduty I would use something to cushion it using this method. (Most possibility for damage if not careful) or just rent a. Engine hoist for the day...
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #3 of 5 Old 01-13-2014, 05:02 PM Thread Starter
RJ's325ITS's Avatar
wait a minute I have and engine hoist!!!
how will this work<<?????
post #4 of 5 Old 01-13-2014, 05:23 PM
alaskan155's Avatar
Quoted: 60 Post(s)
Use some scrap steel or 2x2s and build a H lift in center wood or steel should catch under bed rails if not a long chain attached to 4 corners of bed should be some videos on youtube using this method
Ive seen a few guys online remove entire body from fullsize broncos using nothing but some chain and engine hoist fully extended. Just have to get creative
post #5 of 5 Old 01-15-2014, 04:34 PM
WVRidgeRunner's Avatar
I've used a come-a-long and an H-frame I built out of 2x4s before. Just pulled under my kids' swingset and picked the bed off and then drove out from under it. Bed bolts almost always need cut/torched/ground off before hand
1999.5 707 Conversions Super Duty 7.3 Crew Cab LB Dually 4x4 Edge Evolution, Oil HPx, Fuel FRx, tons of filters, hutched n harpooned, B&W turnover ball and 5th wheel, lotsa goodies.
WVRidgeRunner is offline
