I've recently rebuild the flatbed on my 3/4 ton and i had intended to reuse the existing brake and reverse lights. Unfortunately after i had cut the holes out and installed them i found out one of the brake lights has kicked the bucket. The way the lights are setup it doesn't seem to have a replaceable bulb, more of a sealed unit. If im going to have to replace one im just going to replace them all preferably with new LED lights.
So the question is - Where is the best/cheapest/easiest place to find a 4.5" replacement brake and backup light both led. The light is only a 4" but they have a rubber grommet that goes around them making the hole 4.5". Also by switching to LED is there any thing i need to be aware, i've heard of people having problems because of the different resistance in the LED lights.
