Hids effects fm radio and horn effects god's. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-02-2014, 06:25 AM Thread Starter
jakethesnake1990's Avatar
I got some hids of hidnation, when the hids are on I get a lot of static. And last night I notice if I hit the horn The hids get brighter for a second.
2001 F250 7.3
8 inch lift on 37s
6 Pos ts tony wildman tunes
Pillar gauges
4.56 gears
jasper rear
Stage 1 injectors
Silverline exhaust
Violant intake
Viper keyless start
jakethesnake1990 is offline
post #2 of 6 Old 01-02-2014, 07:02 AM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
Sounds like a bad ground
Please
You could save the life of a sick child
NYC F-350 is offline
The Following User Says Thank You to NYC F-350 For This Useful Post:
jakethesnake1990 (01-02-2014)
post #3 of 6 Old 01-02-2014, 06:23 PM Thread Starter
bad ground from my batteries ?
post #4 of 6 Old 01-04-2014, 05:51 PM
the1laf's Avatar
I tried everything to listen to certain stations at night.. My HID's only affected one station so I just lived without it..
I agree with NYC F-350, check all your connections. I took sandpaper and dielectric grease to all the grounds and it helped quite a bit at start-up.
2000 F-350 Lariat CCLB w. 335,000+ Mi
Tymar intake, Straight 4", 6.0 Intercooler, IDP Competition Fuel System, AC's, SB SD Clutch, ZF6 Short Shift Kit
Gearhead Tunes, Swamps IDM, Snow Performance Water/Meth, Isspro Performax Gauges & 08 Black Leather Seats
05 Harley's, Smoked tails, Weld Racing Sidewinder Wheels
Fried Piston, Re-building engine
330 RWHP Fuel Only - 363 RWHP w. Meth
Broke College kid... Eating Ramon to save for truck parts..
the1laf is offline
post #5 of 6 Old 01-04-2014, 08:01 PM
kclough's Avatar
Try re-grounding the radio. In my old f150 I installed a new radio and would have a whine that was in direct correlation with my rpms. I cut the black wire on my radio and ran a ground to my seat bracket and fixed my issue
kclough is offline
post #6 of 6 Old 01-05-2014, 01:42 PM
Also can add RF choke to the power lead for the HIDs. These are little clip-on things that go around the outside of the wire, no splice required. There are more sophisticated ones which are basically an iron doughnut in two pieces that you wrap the wire around, then snap on the other piece. These will usually kill the RF coming through the electrical system. If its radiating RF, then you need some braided loom shielding.
Any of these items can be had very cheaply at most any ham radio or amateur electronics supply. Radio Shack used to carry such things, but they are no longer interested in the electronics hobbyist business.
alabamatoy is offline
