Wheel help...99-04 to 05-07 - Ford Powerstroke Diesel Forum
Old 09-20-2008, 11:48 AM
Once you go black......
Send a message via MSN to CanadianDiesel
Hey guys, I'm looking for info on what to do if I wanted to put 05 style wheels on my 99 F-350.
What needs to be done, and do you think it's worth it?
I have the factory aluminum (non-polished) rims and will sooner or later change to either chrome or polished alum 05-07 factory style rims..mine are oxidizing and look worse and worse!
Thanks
Old 09-21-2008, 09:06 AM
You need to get high quality wheel spacers to run the 05-08 wheels on a 99-04.
05-08 wheels have more backspacing than the 99-04s.
Old 09-21-2008, 09:09 AM
How much spacing?
Old 09-21-2008, 09:25 AM
1.5" or 2.0" spacer.
You can run the 05-08 wheels without them, but they'll be tucked under the truck and you'll most likely hit the leaf springs with the tires close to full lock.
Old 09-22-2008, 04:22 PM
Great, thanks for the help! Actually I have one more question, may be a stupid one but here it goes...do I need spacers for the back wheels?
Old 09-22-2008, 05:02 PM
If you want them to look the same as the front, yes.
They moved the wheel mounting surface out on the 05+ axles so if you don't use spacers the tires will be further under your 99 than the front wheels with the spacers would be.
Old 09-23-2008, 02:23 PM
Excellent, I'll be giving that a try. A little worried about wheel spacers causing vibrations but I'll see how it goes...
Thanks again
Old 09-23-2008, 05:21 PM
If you get some high quality steel, hub-centric spacers you should be good.
Old 10-07-2008, 07:11 PM
Maybe a silly question, but where can a fellow PS owner get good high quality steel hub-centric spacers?
Old 10-07-2008, 08:17 PM
OperationSmile.org
truck toyz performance
