Urgent help needed during lift! Please im desperate... - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-21-2013, 09:02 PM Thread Starter
kbragg430's Avatar
Im installing a 3.5 inch shackle hanger lift on my 02 f350 and cant get the front springs into the new front hangers. Any advice please?? Im desperate
2002 F350 CCSB SRW 4X4 ~110k
4" MBRP, DIY Tymar, PHP hydra, Edge Insight CTS, 360* thrust, RR billet wheel, delete pedestal and outlet,
Napa ELC, melling 208 Lpop, 6.0 trans cooler, diy coolant filter, 203* thermostat, RR IC boots w/ plenum inserts, frx, hpx, hutch&harpoon
331 hp / 620 tq
Dynod by dynoproven 4/19/14
kbragg430 is offline
post #2 of 9 Old 12-21-2013, 09:18 PM
Raul@Stealth Automotive's Avatar
a lil more detail is needed? why cant you get them in? did your kit come with an adjustable trac bar or relocation bracket?
Raul@Stealth Automotive is offline
post #3 of 9 Old 12-21-2013, 10:22 PM Thread Starter
kbragg430's Avatar
Ive got an adj trac bar but its like the axle is ahifted forward on the passenger side. The kit said to remove the stock teac bar while installing the lift
331 hp / 620 tq
post #4 of 9 Old 12-21-2013, 10:45 PM Thread Starter
kbragg430's Avatar
Do i try to like pull the axle forward with say a tow strap? Im really at a loss
331 hp / 620 tq
post #5 of 9 Old 12-21-2013, 10:47 PM Thread Starter
kbragg430's Avatar
Or can i remove the u bolt brackets move the springs forward? Im done trying to put the lift on. Im now trying to gwt it back together to let a professional finish the job. Is it okay to move the springs forward so i can drive it to a shop?
331 hp / 620 tq
post #6 of 9 Old 12-22-2013, 08:18 AM
you can use a tow strap.... is it a shackle and hanger kit?
post #7 of 9 Old 12-22-2013, 10:24 AM Thread Starter
kbragg430's Avatar
Yes its a shackle hanger kit. Should i take the leafs completely out? Set them, then move and bolt the axle?
331 hp / 620 tq
post #8 of 9 Old 12-22-2013, 12:52 PM
Turbostang500's Avatar
When I was doing my leveling kit, I had to use a strap and a come-along attached to tje trans crossmember to pull the passenger side of the axle backward. It was the only way it was going to line up.
Lee
2000 F250 PSD SCSB 4X4 418k miles straight pipe gauges 2" leveling kit 315/75r16's
6637 with custom intake pipe. TS Performance 6 position chip!
[/URL]
Please don't confuse my attitude with my personality.. my personality is who I am,my attitude depends on who you are...
Turbostang500 is offline
post #9 of 9 Old 12-22-2013, 03:27 PM Thread Starter
kbragg430's Avatar
I was able to use a pallet jack and wood with a big ol ratchet strap to line everything up finally. I was just worried about dropping the axle off. I will never try this again haha
331 hp / 620 tq
