Heated Mirrors? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-20-2013, 07:34 AM Thread Starter
Fire From the Clouds!
Horizon122's Avatar
Quoted: 110 Post(s)
Heated Mirrors?
I just bought a pair of new towing mirrors that are powered and heated. I originally have the smaller mirrors on my truck that are power but not heated. My question is will the heat automatically work once I get them installed or will I need to install a new switch or anything?
2002 Ford F350-Lariat-CrewCab-LongBed-7.3L PowerStroke Intercooled Turbo Diesel!
2.5 Pro Comp lift on 315/75r16 Fierce M/T's
Enough Stuff To Pull Yours!
Horizon122 is offline
post #2 of 5 Old 12-20-2013, 05:32 PM
Quoted: 7 Post(s)
you will have to wire them up and put in a switch. I will likely be doing this project in a couple weeks
Will335i is offline
post #3 of 5 Old 12-20-2013, 06:45 PM Thread Starter
Horizon122's Avatar
Quoted: 110 Post(s)
Also if I plug them in without doing the wire up then just the power should work right?
post #4 of 5 Old 12-21-2013, 10:07 AM
Quoted: 7 Post(s)
As long as it is the same plug it should.
Will335i is offline
post #5 of 5 Old 12-21-2013, 01:12 PM Thread Starter
Horizon122's Avatar
Quoted: 110 Post(s)
Alright thanks man.
