Writup turning helicopter landing skids into running boards - Ford Powerstroke Diesel Forum
post #1 of 17 Old 12-13-2013, 01:41 PM Thread Starter
shordinges's Avatar
Quoted: 14 Post(s)
Garage
Turning helicopter landing skids into running boards
Hey guys this is my first writeup on one of my projects, turning old EC135 helicopter skid tubes into running boards for my 99 f250. Now I didnt really write this as a tutorial on how to do this because i doubt anyone will be able to get their hands on these tubes unless they work in the industry or are willing to chop up skids that cost about $3500 each new. The final product may not look as good as some store bought kits but I like the unique style and the story behind them. So here we go...
Started by collecting 2 "unairworthy" skid tubes from a couple of helicopters in our fleet, here is the picture of the helicopter that i removed the blue tube from
These tubes are considered "unairworthy" when they get a dent that is larger than 1.5 inches in diameter, which both of these are definitely out of limits and are scrap at this point. The dents are from landing on hidden objects such as a rock in a field, this is a medical response helicopter so landing in remote areas is very common and will damage tubes often.
I wanted to make the running board extend past the cab of the truck and be used as a step into the bed of the truck as well, so i made the length of the tube the same as the black door guard trim on the truck. First thing to do was cut the curl off the nose of the tube and drill out the rivets holding on the end caps, then punch out the end caps. I then cut off about a foot of the end to make it the length i wanted.
Next to do was strip the paint off of the tubes so it was just bare aluminum that needed to be primed. And of course mock up the tubes to the truck to see what they might look like. i included the picture from the drivers seat looking down to show that when the door is open there is a lot of the step exposed, when the door is closed the tube is tucked inside the tires of the truck
after reinserting the end caps it was time to prime the bare aluminum and then wet sand
Another mockup now with the EZ oval tube mounting brackets
Now the hard part... each end of the tube has 4 pre drilled holes with nut plates on the inside of the tube so it can be mounted on the helicopter. Because I cant weld the aluminum tube to the steel mounting brackets i have to build a steel cradle to bolt to the underside of the tube and then weld the steel cradle to the brackets on the truck. First step is to cut 8 4" long pieces of steel and then heat them up and shape them to be the same contour of the tube. I will admit that im not the greatest metal worker and didnt have the best tools to do the job, but i made it work for the project i was doing.
then drill the holes in the curved steel to bolt up to the tube and cut the long pieces of steel for the length of the tube
And weld them together, again i know i am not a very good welder but they will hold
Finally reassemble the tube and cradle, position them on the truck where i wanted them and weld the cradle to the brackets. first looks with them on the truck (just primer still)
They look a little close the the cab of the truck but when the door is open they are perfectly functional, they help a lot when trying to get into the back seat. Since these pictures were taken i have unbolted the tube from the cradle and put PRC sealant between the tube and cradle to keep them from slapping eachother while driving down a bumpy road. Im still debating painting them gloss black and add wingwalk (anti skid stuff like rhino lining) to the top so you dont slip off, or if i should just rhino line the entire step.
Anyways i will post a picture when its all done, right now its too cold to paint so i will have to paint it when i get it back in a heated shop again. Thanks again for looking and let me know what you think!
*Bought March 2011 @ 150K / Sold March 2016 @ 230K* E1999 7.3 PS 6 Speed,TS 6 position chip. K&N CAI, 4" straightpipe, Auto Meter Elite gauges.
*Bought May 2016 @ 59K* 07 F250 HD Edition 6.0 Stock
shordinges is offline
post #2 of 17 Old 12-14-2013, 10:11 AM
Eco Taxi's Avatar
Very cool
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #3 of 17 Old 12-14-2013, 10:23 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1074 Post(s)
Feedback Score: 6 reviews
Pretty awesome man! I like the look of them.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #4 of 17 Old 12-14-2013, 11:56 AM
Very cool and definitely unique. Do you have your A&P license by chance? Assuming you do. I have 16 years in the Air Force so far with experience on F-15's, F-22's and F-16's (Crew Chief).....trying to figure out what i wanna do when i'm done with my 20 yrs and have to get a real job lol.
22crew is offline
post #5 of 17 Old 12-14-2013, 02:12 PM
hansel's Avatar
Quoted: 100 Post(s)
Those are so cool
I love helicopters, and what you have done too recycle the parts is awesome.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #6 of 17 Old 12-14-2013, 02:19 PM
turbotibbo's Avatar
those are nice
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #7 of 17 Old 12-14-2013, 02:48 PM
RPM Tim's Avatar
Look great. I like that they don't stick out very far, just enough. May cramp your toes if you do have to get into the bed but looks real clean tucked in like that.
2002
250 CCSB 4x4 7.3
stock~ diy B085011 / DEP 5" Turbo Back w/muffler / Phoenix chip
RPM Tim is offline
post #8 of 17 Old 12-15-2013, 09:49 PM
looks more like sliders than steps...very cool.
I'd have left the original colors, would have added to the story
'03 CCSB
6637
4" Lift
35" Duratracs
...More to come as money allows!
gentimmy is offline
post #9 of 17 Old 12-15-2013, 10:10 PM
Great job. I think a strip of wing walk material would just add to the aircraft theme of it.
97 F350 7.3 super cab full bed dually
Autometer Sport Comp II boost and egt
TS 6pos tuner
Clutch clevis mod
Tymar intake
Stancor/White & Rogers GPR
Dyno test 221.5hp @ 187,000 mi. Before mods.
Other mods soon :
diamond back dp and 4in exh
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #10 of 17 Old 12-16-2013, 03:33 PM Thread Starter
shordinges's Avatar
Quoted: 14 Post(s)
Garage
Thanks guys for the feedback. Yes I'm an A&P and love the job. It's a little more complicated than most AP jobs due to having so many medical equipment mods and knowing that there could be a stray used needle or blood somewhere in the cabin. But i think I will go with the wingwalk on the top. I wanted to safety wire the bolts together too for the aircraft theme but nobody would see it. I'm going to have the pilots that damaged the tube put their signatures next to their dents in silver paint marker to keep the story going. Keeping the colors original would be cool but I just couldn't do it, most of my acessories are black and having yellow and blue running boards would kill me lol
