rims - Ford Powerstroke Diesel Forum
Old 09-03-2008, 05:16 AM
rims
i'm confused on the exact measurements of rims i need to buy, i am running 305-70-r16, i know i need to run 8x170mm, however i don't know if i need a 16x8 or 16x10, i'm pretty sure i need a 16x8. here's the page Series 8089 - Gloss Black
Old 09-03-2008, 08:31 AM
bump..........need any kind of information, don't want to buy the wrong ones
Old 09-03-2008, 08:43 AM
anyone have anything to say.
Old 09-03-2008, 11:07 AM
bump
Old 09-03-2008, 11:10 AM
a truck
A 305/70 is a 12.5" tire so you can do either a 16x8 or 16x10 I have a 16x8 rim with a 12.5" tire so you can go with that but that is the max width of a tire you can go with a 16x8, it is cheaper for that size rim but the tire sticks out more with a 16x10
Old 09-03-2008, 11:15 AM
ok, so go with a 16x8
Old 09-03-2008, 11:26 AM
it will look fine on a 8" wide wheel
Old 09-03-2008, 11:31 AM
ok well i'm not too familar with rims because i've never had to buy any, i just wasn't sure if either a 16x8 or the 16x10 would allow the rim and tire to fit correctly, but after talking you you raul and psd0389 i'll just go with the 16x8
Old 09-03-2008, 11:34 AM
make sure you call and see if they are in stock... i did a quick check and i didnt see them have any of those rims in stock
Old 09-03-2008, 11:42 AM
ya, i was going to do that before i went. but thanks
