| 99-03 7.3L Exterior Discussion Body and Accessories Talk |
Mirrors
Just wondering if i can put 03 mirrors with the turn signal and heat in my truck i got the tow ones but not with the signal and heated. So does it work and hows the wiring?
i second that
+3 bump bump
I've been wanting to do this myself. either teh 03 style, or the new 08's. I believe they are all the same bolt pattern and shape. I assume I can just tap into the existing wiring, I know the wires aren't already there for them. So it'd take soem wiring, but it can be done. I just haven't taken the step to buy em yet.
IIRC you can tap into the wiring for the signals, and you can get a 4wd switch out of a exploder that has the rear defrost button on it, and use that for the mirror defrost.
I heard the mirrors auto defrost for a few seconds everytime you turn the truck on...
Mirrors are always on defrost.
I put signal mirrors in my '02. The wiring is pretty easy if your somewhat familiar with wiring and you have some patience. A friend of mine helped me and we were done within a couple of hours. We tapped the signal and running light wires into the harness under the dash and spliced in the connectors.
This is a good write up for those who want to do it, TheDieselStop.Com - www.thedieselstop.com |
So anyone else know how 2 get the heat 2 work.
