Cab Lights Help! - Ford Powerstroke Diesel Forum
Old 08-26-2008, 07:14 PM
Cab Lights Help!
Me and my brother are gonna attemp to put my cab lights on tmra but there is one problem, my mom threw out the directionsI got the LED Recon Cab Lights that came with the harness just forget where i need to plug the other end of the harness inAny help would be great.....Thanks!!!!
Old 08-26-2008, 07:15 PM
Chug-a-lug!!!
I spliced mine directly into the parking light wire behind the headlight switch. On my '06 it was a brown wire but I would double check.
Old 08-26-2008, 07:22 PM
Send a message via Yahoo to skoalcowboy22
Over on the passenger side behing the a pillar molding is where it plugs in Mantain has a thread about it you can search for
Old 08-26-2008, 07:27 PM
Chug-a-lug!!!
Thats if you purchase the wiring harness from Ford. My harness that came with the lights didnt have a plug in on the end, just the wire. Thats why I spliced into the lights behind the switch.
I highly recommend by small bolts with washers anstead of using the supplied screws!
Old 08-26-2008, 07:34 PM
Thanks for the help gonna give it a shot tmra!!
Old 08-27-2008, 05:28 AM
It ws the brown wire behind the headlight switch on my 05 as well
Old 08-27-2008, 10:26 AM
Does anybody know for sure which wire it is on a 2000 7.3 to splice into the headlight switch?
Old 08-27-2008, 12:21 PM
Found the wire they are all mounted up looks awesome!!! Thanks for the help guys
Old 08-27-2008, 12:29 PM
Congrats on the install!!!
Old 08-27-2008, 07:10 PM
You got it ill get some pics tmra!!
